Autor Thema: Xfce 4.16 released  (Gelesen 327 mal)
Offline virtual-dev
  • Sr. Mitglied
  • Dankeschön: 721 mal
  • Desktop: Xfce4
  • Grafikkarte: Intel HD Graphics 630
  • Grafikkartentreiber: free
  • Kernel: 5.10 LTS
  • Prozessor: i7-7700HQ
  • Skill: Fortgeschritten
  • Zweig: *
Xfce 4.16 released
« am: 23. Dezember 2020, 08:13:32 »
Zitat
Xfce 4.16 released
Today, after 1 year and 4 months of work, we are happy to announce the release of the Xfce desktop 4.16, a new stable version that supersedes Xfce 4.14.
4.16 was a special cycle in many respects (not only pandemic-wise, but also). One of the corner-stones of the non-code changes concerns our migration to GitLab, which is a change in development workflow and a huge step forward in terms of becoming more contributor-friendly and welcoming. In parts, the humungous changelog of Xfce 4.16 can be attributed to new contributors proposing merge requests (288 merge requests were merged or closed against our core components alone!). We also created a reference Docker container (xfce/xfce-build) and added CI pipelines to all components to ensure we don´t break the build. None of this would have been possible without our hosting being sponsored by Gandi and Fosshost!
Another big change concerns our visual identity, which we updated from a strange mix of random (partly Tango-based) icons and not following any naming scheme to a new, visually consistent set (following the freedesktop.org naming specification and a fixed color palette). We´re aware this will generate some work for icon theme maintainers (if they really want to override our gorgeous icons ;)) but we believe the longterm benefit outweighs this one-time effort.
And then finally we did some housekeeping (e.g. by dropping Gtk2 support code) and we also added features and improvements - all while sticking to a reasonable release cycle timeframe.
So without further ado, here go the main highlights of this release:
    The window manager received lots of updates and improvements again in the area of compositing and GLX. If a primary display was set, the alt-tab dialog will now only be shown there. Furthermore some handy new options to zoom the cursor along with rest of the display as well as an option to keep minimized windows in the most recently used list complement this release.
    We added a new plugin to the panel dubbed "statustray" which combines both StatusNotifier and legacy Systray items. An animated autohide transition now clearly shows the user "where the panel has gone" and a dark mode (enabled by default) makes the panel drop into the background a bit more with bright themes like the Gtk default Adwaita. Quite a few more smaller improvements were also introduced like accessing desktop actions from a Launcher´s right-click menu, the Window Buttons plugin now offering to `Launch a new instance` of an application and the Workspace Switcher now optionally showing automatic numbering for workspaces.
    Support for fractional scaling was added to the display dialog, along with highlighting the preferred mode of a display with an asterisk and adding aspect ratios next to resolutions. Falling back to a working mode after misconfiguring the display layout has also been made more robust.
    A new tab in the "About Xfce" dialog shows basic system information like CPU or GPU type. Furthermore the layout and visuals of the dialog were improved.
    The settings manager has improved search and filter capabilities. Furthermore all settings dialogs now use window decorations drawn by Gtk (client side decorations).
    The "Mime Settings" and "Preferred Applications" dialogs were merged into the "Default Applications" dialog - making it easier for users to set which application handles which filetype or action from one place.
    Our file manager Thunar received a boatload of fixes and quite a few notable features, including pause for copy/move operations, support for queued file transfer, remembering view settings per directory and support for transparency in Gtk themes.
    Our thumbnailing service tumbler became more flexible by being able to exclude paths. Furthermore support for .epub (e-book format) was added.
    The session manager offers improved support for GPG agent 2.1 and the setting dialog was visually improved.
    The power manager received a lot of bugfixes and some smaller features - among them a cleanup of its settings dialog, an optional visual indicator for when `Presentation Mode` is enabled, more accurate battery status icons and automatically dismissing low-power notifications upon the connection of a charger.
    The desktop mostly received bugfixes and small improvements - and the new default wallpaper!
    Our menu library garcon received new APIs and now doesn´t launch applications as children of the process hosting the menu anymore. The previous behavior led to applications crashing along with e.g. the panel.
    The applicaton finder now allows for sorting applications by "frecency" - a combination of frequency and recency.
    Dependency updates: Drop Gtk2, add LibGTop, bump Gtk >= 3.22, GLib and GDBus >= 2.50
An online tour of the changes in Xfce 4.16 can be viewed here:
https://www.xfce.org/about/tour416
A detailed overview of the changes between Xfce 4.14 and Xfce 4.16 releases can be found on the following page:
https://www.xfce.org/download/changelogs
Die Veröffentlichung kann entweder als Satz aus einzelnen Paketen oder als umfassendes Tar-Archiv heruntergeladen werden, mit folgenden individuellen Versionen:
https://archive.xfce.org/xfce/4.16
Mit den besten Empfehlungen,
Das Xfce-Entwicklungsteam
Link
Offline tetzlaff
  • Vollwertiges Mitglied
  • Dankeschön: 24 mal
  • Grafikkarte: Nvidia
  • Kernel: 5.10 LTS
  • Prozessor: AMD T1090
  • Skill: Durchschnitt
  • Zweig: stable
Re: Xfce 4.16 released
« Antwort #1 am: 25. Dezember 2020, 19:13:11 »
Hi,
hier noch etwas deutsche Lektüre.
Zitat
XFCE 4.16: Der schlanke Desktop in neuer Version
Aufräumarbeiten im Quellcode entfernen die letzten Reste von GTK2 und zahllose visuelle Änderungen frischen die Oberfläche der freien Desktopumgebung auf.
Keine lange Schaffenspause: XFCE 4.16 erscheint trotz des gleichzeitigen Umzugs der Quellcodes von Cgit auf GitLab weniger als eineinhalb Jahre nach der letzten Ausgabe.
Der Umbau auf das einladende, selbst-gehostete GitLab zahlte sich bereits aus, denn laut der gekürzten Release Notes beteiligten sich dank dem zugänglicheren Infrastruktur bereits etliche neue Entwickler und sorgten damit für ein ellenlanges Changelog.
Die Mitarbeit bescherte XFCE eine um 30 Prozent höhere Zahl von Änderungen in kürzerer Zeit, als zur letzten Ausgabe. Über 280 der fast 1000 einzelnen Änderungen betreffen dabei allein die Kernkomponenten von XFCE 4.16, das sich mit der neuen Version weiteren GTK2-Rudimenten im Code entledigt, clientseitige Fensterdekos willkommen heißt und eine abgestufte Skalierung der Desktopelemente erlaubt. Neben den hunderten Detailverbesserungen präsentiert XFCE 4.16 als gut sichtbare Neuerung ein vereinheitlichtes Symbolset, das den bisherigen Iconmix ersetzt und den Designempfehlungen von Freedesktop.org folgt.
In etwa gleich geblieben ist der Ressourcenbedarf gegenüber der Vorgängerversion. XFCE belegt weiterhin, ohne laufende Programme und je nach Linux-Distribution, zwischen 350 und 500 MB. Es handelt sich also um einen genügsamen Desktop, der trotzdem an Anpassungsmöglichkeiten nicht geizt.
Link
Manjaro, Void, Devuan 3.0
