Autor Thema: plötzliche Schreib und Leserechte weg  (Gelesen 136 mal)
Offline Gast123
  • Vollwertiges Mitglied
  • Dankeschön: 2 mal
  • Skill: Fortgeschritten
« am: 11. März 2021, 18:56:10 »
Wie oben beschrieben wunderte ich mich,warum auf einmal ich keine Dateien oder Apps starten konnte.
Am Ende kann ich nur noch über roots neu booten und mit fsck /dev/sda1 checken.
Daraufhin machte ich ein smartctl -a /dev/sda3 und daraus kam sowas:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.4.101-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Scorpio Black (AF)
Device Model:     WDC WD7500BPKT-75PK4T0
Serial Number:    WD-WX91A61V3040
LU WWN Device Id: 5 0014ee 25b5b3e56
Firmware Version: 01.01A01
User Capacity:    750.156.374.016 bytes [750 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Thu Mar 11 18:51:30 2021 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (12360) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: (   2) minutes.
Extended self-test routine
recommended polling time: ( 123) minutes.
Conveyance self-test routine
recommended polling time: (   5) minutes.
SCT capabilities:        (0x7035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       116
  3 Spin_Up_Time            0x0027   194   191   021    Pre-fail  Always       -       1275
  4 Start_Stop_Count        0x0032   096   096   000    Old_age   Always       -       4816
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   083   083   000    Old_age   Always       -       12804
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   096   096   000    Old_age   Always       -       4815
191 G-Sense_Error_Rate      0x0032   001   001   000    Old_age   Always       -       5748
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       143
193 Load_Cycle_Count        0x0032   120   120   000    Old_age   Always       -       241729
194 Temperature_Celsius     0x0022   105   081   000    Old_age   Always       -       42
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       1
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
240 Head_Flying_Hours       0x0032   086   086   000    Old_age   Always       -       10463
241 Total_LBAs_Written      0x0032   200   200   000    Old_age   Always       -       15359963623
242 Total_LBAs_Read         0x0032   200   200   000    Old_age   Always       -       14943796771
254 Free_Fall_Sensor        0x0032   168   168   000    Old_age   Always       -       32
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed: read failure       90%      8515         27461168
# 2  Short offline       Completed: read failure       90%      8515         27461168
# 3  Short offline       Completed: read failure       90%      8515         27461168
# 4  Short offline       Completed: read failure       90%      8515         27461168
# 5  Extended offline    Completed: read failure       90%      8514         27461168
# 6  Selective offline   Completed: read failure       90%      8514         27461168
# 7  Conveyance offline  Completed: read failure       90%      8514         27461168
# 8  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay
Kann es sein,dass die Festplatte so langsam am Arsch ist?
Offline kisun
  • Dankeschön: 25 mal
  • Desktop: XFCE
  • Grafikkarte: nVidia GeForce GTX 1660 Ti
  • Kernel: 5.10.18-1-MANJARO
  • Prozessor: i5-4690K
  • Skill: Anfänger
  • Zweig: stable
Re: plötzliche Schreib und Leserechte weg
« Antwort #1 am: 11. März 2021, 21:28:06 »
Hallo Gast123.
Bei der Aussage
würde ich das als Festplatte iO deuten. In einem anderen Thread hattest du dich mit dem chmod-Befehl ausgetobt.
Was hast du gemacht bevor das aufgetreten ist? Und wo sind alle Schreib- und Leserechte weg?
« Letzte Änderung: 11. März 2021, 21:44:14 von kisun »
Offline kisun
  • Desktop: XFCE
  • Skill: Anfänger
  • Zweig: stable
« Antwort #2 am: 11. März 2021, 21:53:58 »
Sponatan fällt mir bei dem Thema 'nix geht mehr' eine volle root-partition ein.
df -h
Bei der Ausgabe den Einhängepunkt für root (/) suchen und schauen ob noch Platz auf der Partition ist.
Zitat
Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
/dev/sda1       118G     53G   60G   47% /
Offline Gast123
  • Dankeschön: 2 mal
« Antwort #3 am: 11. März 2021, 22:03:38 »
Ich habe da eine gaaanz andere Vermutung. So banal es auch klingt. Die Batterie meiner kabellosen Maus war noch 55% voll. Könnte aber schon zu niedrig sein. Daher spielte mein Laptop etwas verrückt. Neue Batterie eingesetzt..
Ich beobachte es weiter..
Offline Gast123
  • Dankeschön: 2 mal
« Antwort #4 am: 11. März 2021, 22:24:55 »
Nein,die Maus ist es nicht.
Zu der Frage wegen chmod-Befehlen.
Die Befehle kamen nur aus meinem Laptop per ssh zum Raspberry. Also,kein chmod auf meinen Laptop gemacht.
Ich denke,es war was anderes,was ich vor kurzem getan habe:
Da ich viel Videos auf mkv umgewandelt habe und sah,das auch Handbrake die Videos datenmengenmäßig nochmals verkleinern kann.
Handbrake war zwar sehr langsam,aber nutzte 800% RAM aus und bis es fertig war,dauert es meistens 3 bis 5 Stunden. Deshalb prüfte ich,ob mein Laptop nicht zu heiß wurde. Es war auch so.Deshalb habe ich Handbrake rausgeschmissen und lasse es mit makemkv. Seitdem ist mein Laptop nicht mehr ganz frisch und macht in letzter Zeit nicht so,wie es sollte.
Und nun wird mein Laptop ziemlich schnell heiß und schlapp..
Tja, da muß wohl ein neuer Laptop her..Ist auch schon immerhin 10 Jahre alt..
Offline Gast123
  • Dankeschön: 2 mal
« Antwort #5 am: 18. März 2021, 14:31:51 »
Es hat sicher erledigt.
Der neue Laptop ist angekommen und alles läuft wieder..
thema also abgehakt.
