Vermutlich ja aber ich sehe nichts.
Habe mich mal per ssh draufgeschaltet.
Hier die Ausgaben.
grep EE /var/log/Xorg.0.log
[ 8.008] Current Operating System: Linux chris-pc 5.11.6-1-MANJARO #1 SMP PREEMPT Thu Mar 11 19:05:51 UTC 2021 x86_64
[ 8.014] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 8.014] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 8.015] (EE) Screen 0 deleted because of no matching config section.
[ 8.015] (EE)
[ 8.015] (EE) Cannot run in framebuffer mode. Please specify busIDs for all framebuffer devices
[ 8.015] (EE)
[ 8.015] (EE)
[ 8.015] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 8.015] (EE)
[ 8.015] (EE) Server terminated with error (1). Closing log file.
journalctl -b
-- Journal begins at Thu 2020-12-03 17:25:25 CET, ends at Mon 2021-03-22 15:01:16 CET. --
Mär 22 15:00:45 chris-pc kernel: microcode: microcode updated early to revision 0xe2, date = 2020-07-14
Mär 22 15:00:45 chris-pc kernel: Linux version 5.11.6-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Thu Mar 11 19:05:51 UTC 2021
Mär 22 15:00:45 chris-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=5e79becf-b2f7-497e-aeef-c4055b81a211 rw quiet udev.log_priority=3
Mär 22 15:00:45 chris-pc kernel: KERNEL supported cpus:
Mär 22 15:00:45 chris-pc kernel: Intel GenuineIntel
Mär 22 15:00:45 chris-pc kernel: AMD AuthenticAMD
Mär 22 15:00:45 chris-pc kernel: Hygon HygonGenuine
Mär 22 15:00:45 chris-pc kernel: Centaur CentaurHauls
Mär 22 15:00:45 chris-pc kernel: zhaoxin Shanghai
Mär 22 15:00:45 chris-pc kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Mär 22 15:00:45 chris-pc kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Mär 22 15:00:45 chris-pc kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Mär 22 15:00:45 chris-pc kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Mär 22 15:00:45 chris-pc kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Mär 22 15:00:45 chris-pc kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Mär 22 15:00:45 chris-pc kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
Mär 22 15:00:45 chris-pc kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
Mär 22 15:00:45 chris-pc kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
Mär 22 15:00:45 chris-pc kernel: BIOS-provided physical RAM map:
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009c3ff] usable
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x000000000009c400-0x000000000009ffff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000743c4fff] usable
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000743c5000-0x00000000743c5fff] ACPI NVS
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000743c6000-0x00000000743c6fff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000743c7000-0x000000007bf79fff] usable
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x000000007bf7a000-0x000000007c2dafff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x000000007c2db000-0x000000007c442fff] usable
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x000000007c443000-0x000000007cae8fff] ACPI NVS
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x000000007cae9000-0x000000007d3fefff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x000000007d3ff000-0x000000007d3fffff] usable
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x000000007d400000-0x000000007fffffff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Mär 22 15:00:45 chris-pc kernel: BIOS-e820: [mem 0x0000000100000000-0x000000047effffff] usable
Mär 22 15:00:45 chris-pc kernel: NX (Execute Disable) protection: active
Mär 22 15:00:45 chris-pc kernel: SMBIOS 3.0 present.
Mär 22 15:00:45 chris-pc kernel: DMI: MSI MS-7976/Z170A GAMING M7 (MS-7976), BIOS 1.L0 06/28/2018
Mär 22 15:00:45 chris-pc kernel: tsc: Detected 4000.000 MHz processor
Mär 22 15:00:45 chris-pc kernel: tsc: Detected 3999.984 MHz TSC
Mär 22 15:00:45 chris-pc kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Mär 22 15:00:45 chris-pc kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Mär 22 15:00:45 chris-pc kernel: last_pfn = 0x47f000 max_arch_pfn = 0x400000000
Mär 22 15:00:45 chris-pc kernel: MTRR default type: write-back
Mär 22 15:00:45 chris-pc kernel: MTRR fixed ranges enabled:
Mär 22 15:00:45 chris-pc kernel: 00000-9FFFF write-back
Mär 22 15:00:45 chris-pc kernel: A0000-BFFFF uncachable
Mär 22 15:00:45 chris-pc kernel: C0000-FFFFF write-protect
Mär 22 15:00:45 chris-pc kernel: MTRR variable ranges enabled:
Mär 22 15:00:45 chris-pc kernel: 0 base 0080000000 mask 7F80000000 uncachable
Mär 22 15:00:45 chris-pc kernel: 1 base 007E000000 mask 7FFE000000 uncachable
