Autor Thema: Docky startet nicht mehr  (Gelesen 2299 mal)
Offline Stargate
  • Neuling
  • Carpe Diem
  • Desktop: Openbox
  • Skill: Anfänger
  • Zweig: stable
« am: 05. November 2014, 18:18:58 »
Hallo
Seit ein paar Tagen startet "Docky" nicht mehr!
Beim Aufruf über das Terminal bekomme ich folgende Meldung:
[Info  18:13:45.034] Docky version: 2.2.0 Release
[Info  18:13:45.050] Kernel version: 3.12.30.1
[Info  18:13:45.051] CLR version: 4.0.30319.17020
[Error 18:13:45.236] [SystemService] Could not initialize power manager dbus: 'Could not load type 'Docky.Services.SystemService+IUPowerProxy' from assembly 'DBus.Proxies, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' because it is implements the inaccessible interface 'Docky.Services.SystemService+IUPower'.'
[Info  18:13:45.237] [SystemService]   at System.Reflection.Emit.TypeBuilder.CreateTypeInfo () [0x00000] in <filename unknown>:0
  at System.Reflection.Emit.TypeBuilder.CreateType () [0x00000] in <filename unknown>:0
  at DBus.TypeImplementer.GetImplementation (System.Type declType) [0x00000] in <filename unknown>:0
  at DBus.BusObject.GetObject (DBus.Connection conn, System.String bus_name, DBus.ObjectPath object_path, System.Type declType) [0x00000] in <filename unknown>:0
  at DBus.Connection.GetObject (System.Type type, System.String bus_name, DBus.ObjectPath path) [0x00000] in <filename unknown>:0
  at DBus.Connection.GetObject[IUPower] (System.String bus_name, DBus.ObjectPath path) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.InitializeBattery () [0x00000] in <filename unknown>:0
[Error 18:13:45.239] [SystemService] Could not initialize Network Manager dbus: 'Could not load type 'Docky.Services.SystemService+INetworkManagerProxy' from assembly 'DBus.Proxies, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' because it is implements the inaccessible interface 'Docky.Services.SystemService+INetworkManager'.'
[Info  18:13:45.240] [SystemService]   at System.Reflection.Emit.TypeBuilder.CreateTypeInfo () [0x00000] in <filename unknown>:0
  at DBus.Connection.GetObject[INetworkManager] (System.String bus_name, DBus.ObjectPath path) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.InitializeNetworkManager () [0x00000] in <filename unknown>:0
[Info  18:13:45.246] [ThemeService] Setting theme: Classic
[Warn  18:13:45.264] [DesktopItemService] Could not find remap file '/home/stargate/.local/share/docky/remaps.ini'!
[Info  18:13:45.401] [DockServices] Dock services initialized.
[Info  18:13:45.626] [PluginManager] Loaded "Trash".
[Info  18:13:45.644] [PluginManager] Loaded "Session Manager".
[Error 18:13:45.648] [SystemService] Could not initialize needed dbus service: 'Could not load type 'SessionManager.SystemManager+IUPowerProxy' from assembly 'DBus.Proxies, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' because it is implements the inaccessible interface 'SessionManager.SystemManager+IUPower'.'
[Info  18:13:45.648] [SystemService]   at System.Reflection.Emit.TypeBuilder.CreateTypeInfo () [0x00000] in <filename unknown>:0
  at SessionManager.SystemManager.Initialize () [0x00000] in <filename unknown>:0
Unhandled Exception:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IndexOutOfRangeException: Array index is out of range.
  at Docky.Items.ProxyDockItem.ItemChanged () [0x00000] in <filename unknown>:0
  at Docky.Items.ProxyDockItem..ctor (Docky.Items.AbstractDockItemProvider provider, IPreferences prefs) [0x00000] in <filename unknown>:0
  at SessionManager.SessionManagerItem..ctor () [0x00000] in <filename unknown>:0
  at SessionManager.SessionManagerItemProvider..ctor () [0x00000] in <filename unknown>:0
  at (wrapper managed-to-native) System.Reflection.MonoCMethod:InternalInvoke (System.Reflection.MonoCMethod,object,object[],System.Exception&)
  at System.Reflection.MonoCMethod.InternalInvoke (System.Object obj, System.Object[] parameters) [0x00000] in <filename unknown>:0
  --- End of inner exception stack trace ---
  at System.Activator.CreateInstance (System.Type type, Boolean nonPublic) [0x00000] in <filename unknown>:0
  at System.Activator.CreateInstance (System.Type type) [0x00000] in <filename unknown>:0
  at Mono.Addins.TypeExtensionNode.CreateInstance () [0x00000] in <filename unknown>:0
  at Mono.Addins.InstanceExtensionNode.GetInstance () [0x00000] in <filename unknown>:0
  at Docky.PluginManager.ObjectFromAddin[AbstractDockItemProvider] (System.String extensionPath, System.String addinID) [0x00000] in <filename unknown>:0
  at Docky.PluginManager.ItemProviderFromAddin (System.String addinID) [0x00000] in <filename unknown>:0
  at Docky.Interface.DockPreferences.BuildItemProviders () [0x00000] in <filename unknown>:0
  at Docky.Interface.DockPreferences..ctor (System.String dockName) [0x00000] in <filename unknown>:0
  at Docky.DockController.CreateDocks () [0x00000] in <filename unknown>:0
  at Docky.DockController.Initialize () [0x00000] in <filename unknown>:0
  at Docky.Docky.Main (System.String[] args) [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IndexOutOfRangeException: Array index is out of range.
[stargate@Holgi ~]$ DISPLAY=:0 docky
[Info  18:14:06.644] Docky version: 2.2.0 Release
[Info  18:14:06.660] Kernel version: 3.12.30.1
[Info  18:14:06.661] CLR version: 4.0.30319.17020
[Error 18:14:06.862] [SystemService] Could not initialize power manager dbus: 'Could not load type 'Docky.Services.SystemService+IUPowerProxy' from assembly 'DBus.Proxies, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' because it is implements the inaccessible interface 'Docky.Services.SystemService+IUPower'.'
[Info  18:14:06.864] [SystemService]   at System.Reflection.Emit.TypeBuilder.CreateTypeInfo () [0x00000] in <filename unknown>:0
[Error 18:14:06.866] [SystemService] Could not initialize Network Manager dbus: 'Could not load type 'Docky.Services.SystemService+INetworkManagerProxy' from assembly 'DBus.Proxies, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' because it is implements the inaccessible interface 'Docky.Services.SystemService+INetworkManager'.'
[Info  18:14:06.866] [SystemService]   at System.Reflection.Emit.TypeBuilder.CreateTypeInfo () [0x00000] in <filename unknown>:0
[Info  18:14:06.872] [ThemeService] Setting theme: Classic
[Warn  18:14:06.891] [DesktopItemService] Could not find remap file '/home/stargate/.local/share/docky/remaps.ini'!
[Info  18:14:07.024] [DockServices] Dock services initialized.
[Info  18:14:07.244] [PluginManager] Loaded "Trash".
[Info  18:14:07.261] [PluginManager] Loaded "Session Manager".
[Error 18:14:07.264] [SystemService] Could not initialize needed dbus service: 'Could not load type 'SessionManager.SystemManager+IUPowerProxy' from assembly 'DBus.Proxies, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' because it is implements the inaccessible interface 'SessionManager.SystemManager+IUPower'.'
[Info  18:14:07.264] [SystemService]   at System.Reflection.Emit.TypeBuilder.CreateTypeInfo () [0x00000] in <filename unknown>:0
« Letzte Änderung: 05. November 2014, 18:21:24 von klesk »
Offline klesk
  • Held Mitglied
  • Dankeschön: 142 mal
  • Desktop: herbstluftwm
  • Grafikkartentreiber: nvidia 3.40xx
  • Kernel: 4.2
  • Prozessor: Intel Core2 Quad Q9550 (-MCP-)
  • Skill: Durchschnitt
  • Zweig: unstable
Re: Docky startet nicht mehr
« Antwort #1 am: 05. November 2014, 19:18:18 »
Hast du ein Laptop ? und in docky irgendwie eine Ladestatus-Anzeige ?
Offline Stargate
  • Neuling
  • Carpe Diem
  • Desktop: Openbox
  • Skill: Anfänger
  • Zweig: stable
« Antwort #2 am: 05. November 2014, 19:29:51 »
Nein
Es handelt sich um einen ganz normalen Desktop-PC
Interessanterweise tritt dieses Problem nur bei Manjaro auf, und dies auch erst seit Kurzem...
Offline klesk
  • Held Mitglied
  • Kernel: 4.2
  • Zweig: unstable
« Antwort #3 am: 05. November 2014, 19:55:05 »
Ich hab mal bisschen recherchiert und scheinbar scheint das bei docky zurzeit ein Problem zu sein.
Die Version in den Repos scheint auch etwas veraltet zu sein.
Ich hab aber gelesen das es in Version 2.2.1 gefixed sein soll die es aber weder in unseren Repos, noch um AUR gibt. Bleibt wohl nur abzuwarten oder jemand hier hat noch andere Infos.
Eine andere Möglichkeit wäre es mal die docky-bzr, aus dem AUR, auszuprobieren.
Das es bei anderen Distros NOCH läuft kann immer daran liegen das dort einige Änderungen noch nicht eingearbeitet wurden.
Wie gesagt sind jetzt die Infos die ich so habe, eventuell hat hier ein anderer noch weitere Informationen.
Offline Stargate
  • Neuling
  • Carpe Diem
  • Desktop: Openbox
  • Skill: Anfänger
  • Zweig: stable
« Antwort #4 am: 05. November 2014, 20:00:39 »
Danke
Dann werde ich zunächst mal abwarten.
Offline Verändert
  • Support Team
  • Dankeschön: 62 mal
  • Ni Dieu ni maître
  • Desktop: Gnome. LXQt. i3.
  • Grafikkarte: Intel & Radeon & NVidia
  • Grafikkartentreiber: frei natürlich
  • Kernel: Immer der aktuelle.
  • Prozessor: Intel Celeron und andere.
  • Skill: Anfänger
  • Zweig: unstable
« Antwort #5 am: 13. November 2014, 07:45:43 »
In Arch ist jetzt 2.2 verfügbar, sollt also bald auch für Manjaro kommen.
Offline Verändert
  • Support Team
  • Ni Dieu ni maître
  • Skill: Anfänger
  • Zweig: unstable
« Antwort #6 am: 13. November 2014, 11:29:52 »
Da sind wir schon zwei, @mozon. Aber die bzr-Version im AUR sollte neuer sein.
