Autor Thema: Manjaro Linux 15.09rc3 nouveau/NVidia Problem  (Gelesen 771 mal)
Offline SpiritOfTux
  • Held Mitglied
  • Dankeschön: 183 mal
  • Desktop: KDE Plasma, Deepin
  • Grafikkartentreiber: On: NB intel/nvidia, HTPC nvidia, PowerWorkStation nvidia
  • Kernel: 4.14.y LTS, 4.9.y LTS,
  • Skill: Fortgeschritten
  • Zweig: stable 17.1.y on PowerWorkStation, NB, HTPC, Desktop:s: Testing or Unstable only VM
« am: 18. September 2015, 12:22:16 »
Sep 18 11:27:49 hometheater kernel: fb: switching to nouveaufb from EFI VGA
Sep 18 11:27:49 hometheater kernel: Console: switching to colour dummy device 80x25
Sep 18 11:27:49 hometheater kernel: nouveau  [  DEVICE][0000:01:00.0] BOOT0  : 0x0ce000a1
Sep 18 11:27:49 hometheater kernel: nouveau  [  DEVICE][0000:01:00.0] Chipset: GF114 (NVCE)
Sep 18 11:27:49 hometheater kernel: nouveau  [  DEVICE][0000:01:00.0] Family : NVC0
Sep 18 11:27:49 hometheater kernel: nouveau  [   VBIOS][0000:01:00.0] using image from PRAMIN
Sep 18 11:27:49 hometheater kernel: nouveau  [   VBIOS][0000:01:00.0] BIT signature found
Sep 18 11:27:49 hometheater kernel: nouveau  [   VBIOS][0000:01:00.0] version 70.24.2e.00.00
Sep 18 11:27:49 hometheater kernel: nouveau  [  PTHERM][0000:01:00.0] FAN control: PWM
Sep 18 11:27:49 hometheater kernel: nouveau  [  PTHERM][0000:01:00.0] fan management: automatic
Sep 18 11:27:49 hometheater kernel: nouveau  [  PTHERM][0000:01:00.0] internal sensor: yes
Sep 18 11:27:49 hometheater kernel: nouveau  [     CLK][0000:01:00.0] 03: core 50 MHz memory 135 MHz
Sep 18 11:27:49 hometheater kernel: nouveau  [     CLK][0000:01:00.0] 07: core 405 MHz memory 324 MHz
Sep 18 11:27:49 hometheater kernel: nouveau  [     CLK][0000:01:00.0] 0f: core 822 MHz memory 2004 MHz
Sep 18 11:27:49 hometheater kernel: nouveau  [     CLK][0000:01:00.0] --: core 50 MHz memory 135 MHz
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] VRAM: 2048 MiB
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] GART: 1048576 MiB
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] TMDS table version 2.0
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB version 4.0
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB outp 00: 04000310 00000000
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB outp 01: 02011300 00000000
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB outp 02: 01011302 00020030
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB outp 03: 02022362 00020010
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB outp 04: 08033382 00020030
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB conn 00: 00000000
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB conn 01: 00001130
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB conn 02: 00002261
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] DCB conn 03: 00010330
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] MM: using COPY0 for buffer copies
Sep 18 11:27:49 hometheater kernel: nouveau  [     DRM] allocated 1920x1080 fb: 0x60000, bo ffff8804063fa000
Sep 18 11:27:49 hometheater kernel: fbcon: nouveaufb (fb0) is primary device
Sep 18 11:27:49 hometheater kernel: Console: switching to colour frame buffer device 240x67
Sep 18 11:27:49 hometheater kernel: nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
Sep 18 11:27:49 hometheater kernel: nouveau 0000:01:00.0: registered panic notifier
Sep 18 11:27:49 hometheater kernel: [drm] Initialized nouveau 1.2.2 20120801 for 0000:01:00.0 on minor 0
Sep 18 11:27:49 hometheater kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 18 11:27:49 hometheater kernel: Disabling lock debugging due to kernel taint
Sep 18 11:27:49 hometheater kernel: NVRM: The NVIDIA probe routine was not called for 1 device(s).
Sep 18 11:27:49 hometheater kernel: NVRM: This can occur when a driver such as:
                                    NVRM: nouveau, rivafb, nvidiafb or rivatv
                                    NVRM: was loaded and obtained ownership of the NVIDIA device(s).
Sep 18 11:27:49 hometheater kernel: NVRM: Try unloading the conflicting kernel module (and/or
                                    NVRM: reconfigure your kernel without the conflicting
                                    NVRM: driver(s)), then try loading the NVIDIA kernel module
                                    NVRM: again.
Sep 18 11:27:49 hometheater kernel: NVRM: No NVIDIA graphics adapter probed!
Sep 18 11:27:49 hometheater kernel: [drm] Module unloaded
Sep 18 11:27:49 hometheater kernel: NVRM: NVIDIA init module failed!
Sep 18 11:27:56 hometheater kernel: nouveau E[   PDISP][0000:01:00.0] INVALID_VALUE [UNK84] chid 0 mthd 0x0828 data 0x000099bb
Sep 18 11:28:14 hometheater kdeinit5[868]: kscreen.kded: Calculating config ID for KScreen::Config(0x1a28af0)
Sep 18 11:28:14 hometheater kdeinit5[868]: kscreen.kded:         Part of the Id:  "7dc4196a664bbc761f9d984c0a8eccca"
Sep 18 11:28:14 hometheater kdeinit5[868]: kscreen.kded:         Config ID: "6f5df5dc308bb3912d3dc1b2a34a37b8"
Sep 18 11:28:14 hometheater kdeinit5[868]: kscreen.kded: Applying known config "6f5df5dc308bb3912d3dc1b2a34a37b8"
Sep 18 11:28:14 hometheater kdeinit5[868]: kscreen: Primary output changed from KScreen::Output(Id: 99 , Name: "HDMI-1" ) ( "HDMI-1" ) to KScreen::Output(Id: 99 , Name: "HDMI-1" ) ( "HDMI-1" )
Sep 18 11:28:14 hometheater kdeinit5[868]: kscreen.kded: Finding a mode for QSize(1920, 1080) @ 50
Sep 18 11:28:14 hometheater kdeinit5[868]: kscreen.kded:         Found:  "104"   QSize(1920, 1080) @ 50
Sep 18 11:28:14 hometheater kdeinit5[868]: kscreen: Primary output changed from KScreen::Output(Id: 99 , Name: "HDMI-1" ) ( "HDMI-1" ) to KScreen::Output(NULL) ( "none" )
Sep 18 11:28:14 hometheater kdeinit5[868]: kscreen.kded: doApplyConfig()
Sep 18 11:28:14 hometheater kscreen_backend_launcher[1054]: kscreen: Primary output changed from KScreen::Output(Id: 99 , Name: "HDMI-1" ) ( "HDMI-1" ) to KScreen::Output(Id: 99 , Name: "HDMI-1" ) ( "HDMI-1" )
Sep 18 11:28:14 hometheater kscreen_backend_launcher[1054]: kscreen.xrandr: XRandR::setConfig
MyVideo Card
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF114 [GeForce GTX 560 Ti] [10de:1200] (rev a1)
Monitor wird nicht richtig angesteuert
Bildschirm hat einen Versatz nach RECHTS, lief unter 0.8.13 alles Problem los
