Autor Thema: Arch Linux on your Android phone  (Gelesen 650 mal)
Offline SpiritOfTux
  • Held Mitglied
  • Dankeschön: 183 mal
  • Desktop: KDE Plasma, Deepin
  • Grafikkartentreiber: On: NB intel/nvidia, HTPC nvidia, PowerWorkStation nvidia
  • Kernel: 4.14.y LTS, 4.9.y LTS,
  • Skill: Fortgeschritten
  • Zweig: stable 17.1.y on PowerWorkStation, NB, HTPC, Desktop:s: Testing or Unstable only VM
« am: 07. Dezember 2015, 21:11:32 »
In this tutorial I will show you one of methods how to install Arch linux together with your android system on your phone.
This method WILL NOT REPLACE your current android system and is safe to use for everybody. It uses independent file which is mounted and you are chrooted to this system. After you can connect via SSH, VNC directly from your phone, PC …     http://www.unixmen.com/arch-linux-android-phone/
Folgende Mitglieder bedankten sich: video4tux
