Shame on me; hatte vergessen zu erwähnen, dass ich die entsprechende Treiberdatei aus dem AUR versucht hatte zu installieren ... Angeblich ist alles ok. Siehe bitte folgende Wiedergabe der KDE-Konsole:
[blub@blub uld]$ sudo ./install.sh
**** Running install ...
**** Press 'Enter' to continue or 'q' and then 'Enter' to quit. :
END-USER LICENSE AGREEMENT FOR SAMSUNG ELECTRONICS SOFTWARE PRODUCT
IMPORTANT-READ CAREFULLY: This Samsung Electronics End-User License Agreement ("EULA") is
a legal agreement between you (either an individual or a single entity) and Samsung Electr
onics Co., Ltd. ("SAMSUNG ELECTRONICS") with respect to the SAMSUNG ELECTRONICS software p
roduct intended to be used with the SAMSUNG devices. The SAMSUNG ELECTRONICS software prod
uct may include associated software components, media, printed materials and "online" or e
lectronic documentation developed and provided by SAMSUNG ELECTRONICS ("SOFTWARE PRODUCT")
. For all other third party software products which may be supplied with or for the SAMSUN
G devices, your use of such software products shall be subject to separate terms of use an
d end user license agreements of such third parties. By installing, copying, downloading
or using the SOFTWARE PRODUCT, you agree to be bound by the terms of this EULA. If you do
not agree to the terms of this EULA, you may not install or use the SOFTWARE PRODUCT.
1. GRANT OF LICENSE.
The SOFTWARE PRODUCT is licensed, not sold. Subject to the condition that you are in compl
iance with the terms of this EULA, SAMSUNG ELECTRONICS grants you the following licenses:
(a) you may install and use one copy of the SOFTWARE PRODUCT, or any prior version for the
same operating system, on a single computer for use by a single simultaneous operator; an
d (b) you may install a single copy of the SOFTWARE PRODUCT, strictly for your own persona
l use, on one portable computer owned by you. No other use, copying or distribution of the
SOFTWARE PRODUCT is permitted. Your use of the SOFTWARE PRODUCT shall be subject to restr
ictions and limitations as specified in this EULA. You cannot modify the SOFTWARE PRODUCT
or disable any licensing or control features of the SOFTWARE PRODUCT directly. If the SOF
TWARE PRODUCT is licensed for concurrent use, you may not allow more than the maximum numb
er of authorized Samsung devices and users to use the SOFTWARE PRODUCT concurrently. If y
**** Do you agree ? [y/n] : y
**** The same version of Print driver is already installed.
**** The same version of Scan driver is already installed.
**** Install finished.
[blub@blub uld]$
