Autor Thema: Manjaro-Lxqt 16.04 released  (Gelesen 1977 mal)
Offline virtual-dev
  • Sr. Mitglied
  • Dankeschön: 694 mal
    • systemdfree
  • Desktop: Xfce4
  • Grafikkarte: Intel HD Graphics 630
  • Grafikkartentreiber: free
  • Kernel: 4.19 LTS
  • Prozessor: i7-7700HQ
  • Skill: Fortgeschritten
  • Zweig: *
« am: 01. April 2016, 17:12:28 »
The Manjaro Community is proud to present our new Lxqt Edition.
Manjaro-Lxqt aims to be light, fast and resource friendly, yet at the same time complete and ready to use for all typical everyday office- and multimedia-needs.
Screenshots
Clean :
Dirty :
Zitat
Main programs
- kernel 4.4.6 LTS, Manjaro settings manager, sddm, octopi, compton, redshift
- pcmanfm-qt, gimp, lximage-qt
- chromium (64 bits) or firefox (32), hexchat, transmission-qt
- abiword, qpdfview, gnumeric(64)
- mpv, smplayer(mpv based) with all skins and themes. 32 -> qastools, 64 -> pulseaudio and pavucontrol
- gparted, qisousb, lxtask, xsensors
- multilib enabled (64)
- capture tool + key Print Screen configured for taking screenshots (also with Alt or Shift)
This release comes with our advanced graphical installer Calamares as well as our CLI-installer. Stable branch was used to create these install medias.
Download
What is changed
- menu item  leave connected to i3lock with blur
- gnumeric added to 64 bits
- calendar is now readable
- shortcut reboot moved at the right
- new sddm theme futuristic
- a lot of enhancements for french translation
- lila-hd icons theme added to the 64 bits (and to AUR)
- bug on default applications solved
- by default, no notification if a removable disjk is connected
- speedcrunch replaced by kcalc
- smplayer-mpv replace by smplayer-svn (AUR), skins and themes added
- white backgrounds changed (FFFFFF -> F8F8F8) for less eyestrain
- incosolata replaces monospace
- root partially themed
- administrator terminal works now
- capture tool added to the menu
Known default
It can happens than you get the message "A stop job is running for ..." at shutdown or reboot, and must wait 1'30". This is not specific to lxqt, I have that too under fce.
In Lxqt, "Magic keys" are activated. So, instead of wait so long, you can press :
Alt + Print screen + B for reboot, or
Alt + Print Screen + E for shutdown.
Do only that in this case, in can be too hard on running applications
« Last Edit: Today at 15:42:44 by Esclapion »
Link
« Letzte Änderung: 01. April 2016, 17:18:08 von virtual-dev »
Folgende Mitglieder bedankten sich: FZR
Offline FZR
  • Vollwertiges Mitglied
  • Dankeschön: 6 mal
  • Desktop: xfce4
  • Grafikkarte: Nvidia GTX 1080 Ti
  • Kernel: 4.19
  • Prozessor: AMD Ryzen 1900X
  • Skill: Durchschnitt
  • Zweig: Artix
Re: Manjaro-Lxqt 16.04 released
« Antwort #1 am: 02. April 2016, 15:33:29 »
Naja, sah auch schon mal schöner aus  8) Aber super wie immer, danke.
Server OS: Devuan 2.0
Offline Frieder
  • Jr. Mitglied
  • Dankeschön: 11 mal
  • Desktop: Plasma5, LXQT
  • Grafikkarte: Intel HD3000
  • Grafikkartentreiber: i915
  • Kernel: den aktuellsten
  • Prozessor: i5
  • Zweig: unstable
« Antwort #2 am: 06. April 2016, 16:08:05 »
einfach mal an generelles "Danke schön" an die Comunity → ich nutze LXQT (15.12)  bereits seit ner Weile und ich muss zugeben, ich bin total angetan davon.
Aktuell fahre ich es mit `unstable` und auch das läuft ziemlich geschmeidig → weiter so  :)
Je mehr man schon weiß, je mehr hat man noch zu lernen. Mit dem Wissen nimmt das Nichtwissen in gleichem Grade zu, oder vielmehr das Wissen des Nichtwissens.
Offline ElGato
  • Neuling
  • Dankeschön: 1 mal
  • Desktop: XFCE
  • Kernel: derzeit 4.14
  • Prozessor: Intel Pentium CPU B950 @2.1 GHz
  • Skill: Anfänger
  • Zweig: stable
« Antwort #3 am: 08. April 2016, 08:17:01 »
Hab das gestern mal auf nem Stick probiert weil meine zwar aktuelle aber doch ziemlich verbastelte (von mir!) Version in XFCE ziemlich zickig geworden ist (basteln ohne Ahnung - immer eine Suuuper Idee.).
Muss sagen: Die Lxqt-Version hat mir ausnehmend gut gefallen! Ich überlege ernsthaft die Kiste komplett platt zu machen und mirr diese Version zu installieren. Muss nur noch etwas probieren ob mir etwas gravierendes fehlen würde was nicht ohne weiteres nachzuinstallieren wäre.
Ansonsten: Danke an die Entwickler (vor allem exclapion wenn ich das richtig verfolgt habe) und fette Kudos!
Bussi,
WElGato
