Autor Thema: [Update] 2016-04-10 - GTK/Gnome 3.20, Mesa 11.2, Most themes broken!  (Gelesen 2427 mal)
Offline virtual-dev
  • Sr. Mitglied
  • Dankeschön: 694 mal
    • systemdfree
  • Desktop: Xfce4
  • Grafikkarte: Intel HD Graphics 630
  • Grafikkartentreiber: free
  • Kernel: 4.19 LTS
  • Prozessor: i7-7700HQ
  • Skill: Fortgeschritten
  • Zweig: *
Zitat
I'm happy to announce another review of Manjaro 15.12 (Capella)!
With this we updated Gnome and GTK to 3.20. This will break most of the themes
and will be fixed as soon as we had time to port them. It is recommended to
use Adwaita or any theme which is already compatible with the new CSS style of
Gnome. Also we have now MESA 11.2 in our repositories.
Archlinux upstream fixes are now from: Sun Apr 10 11:21:16 CEST 2016.
It is always good to check for updated packages, even we don't notify you
about them. As usual people using our testing branch will help us to get snaps
over to our stable branch almost smoothly. For notifications on daily bases
please take a look at our mailing list:
https://lists.manjaro.org/pipermail/manjaro-packages/
Kind regards,
Philip Müller and the Manjaro Development Team
:: Current supported kernels
 - Linux310 3.10.101
 - Linux312 3.12.57
 - Linux313 3.13.11.38
 - Linux314 3.14.65
 - Linux316 3.16.7.26
 - Linux318 3.18.30
 - Linux319 3.19.8.18
 - Linux41  4.1.21
 - Linux42  4.2.8.7
 - Linux44  4.4.6
 - Linux45  4.5
 - Linux46  4.6-rc2
« Letzte Änderung: 02. August 2016, 05:50:53 von virtual-dev »
Offline SpiritOfTux
  • Held Mitglied
  • Dankeschön: 183 mal
  • Desktop: KDE Plasma, Deepin
  • Grafikkartentreiber: On: NB intel/nvidia, HTPC nvidia, PowerWorkStation nvidia
  • Kernel: 4.14.y LTS, 4.9.y LTS,
  • Zweig: stable 17.1.y on PowerWorkStation, NB, HTPC, Desktop:s: Testing or Unstable only VM
Re: [Update] 2016-04-10 - GTK/Gnome 3.20, Mesa 11.2, Most themes broken!
« Antwort #1 am: 10. April 2016, 20:27:16 »
Falls ;)
INFO: Nach Upgrade auf Gnome 3.20: GDM / Gnome startet nicht (Arch)
https://thomas-leister.de/allgemein/nach-upgrade-auf-gnome-3-20-gdm-gnome-startet-nicht-arch/
Offline Verändert
  • Support Team
  • Dankeschön: 62 mal
  • Ni Dieu ni maître
  • Desktop: Gnome. LXQt. i3.
  • Grafikkarte: Intel & Radeon & NVidia
  • Grafikkartentreiber: frei natürlich
  • Kernel: Immer der aktuelle.
  • Prozessor: Intel Celeron und andere.
  • Skill: Anfänger
  • Zweig: unstable
« Antwort #2 am: 11. April 2016, 08:00:03 »
Mit LightDM gibt es allerdings keine Probleme. Bisher jedenfalls.
Offline klesk
  • Held Mitglied
  • Dankeschön: 142 mal
  • Desktop: herbstluftwm
  • Grafikkartentreiber: nvidia 3.40xx
  • Kernel: 4.2
  • Prozessor: Intel Core2 Quad Q9550 (-MCP-)
  • Skill: Durchschnitt
  • Zweig: unstable
« Antwort #3 am: 11. April 2016, 19:28:39 »
Nicht alle Themes sind bisher im Umgang mit GTK 3.20 gewappnet.
sdoubleyou
  • Gast
« Antwort #4 am: 12. April 2016, 09:32:22 »
evtl. muss ja auch die gtk-engine-murrine angepasst werden  ::)
LuMI
  • Gast
« Antwort #5 am: 12. April 2016, 10:09:26 »
Ich bleibe bei GTK2;
Problem gelöst   ;)  ;D
MfG
GypsyWolve
  • Gast
« Antwort #6 am: 12. April 2016, 11:22:51 »
Hbe kein unstable aber dafuer arch C:-)
Im Grunde finde ich sowas Klasse..................
Nutze 2 Anwendungen unter GTK3 da fehlt nur der "scroll-Balken" und die Menuepkts sind zusammen geschoben.
Warum hier eine Aufwaertskompatibilitaet geschaffen wurde, vllt wissen es die devs.
Nach etwas rumgesuche fand ich vereinzelte themes, also Geduld die werden irgenwann auf den Markt kommen
Zumindest bleibe ich, trotzt kleiner Fehler, beim alten Template.
Unter lightdm hatte ich eine transparente incl Rahmen etc pp Eingabemaske, hier ist nur eine sehr interessante komplette transparente ohne Verzierungen Eingabemaske entstanden...............Aber sie funktioniert wie gehabt
GW
