Autor Thema: DVB-T Device wird nicht in Anwendungen erkannt  (Gelesen 1500 mal)
Offline Hansi
  • Neuling
  • Desktop: Manjaro XFCE
  • Grafikkarte: Intel
  • Prozessor: Intel
  • Skill: Anfänger
« am: 25. Januar 2014, 17:55:14 »
Hallo,
bin neu hier und wollte meinen Hauppauge HVR930C an meinem Thinkpad X200 benutzen. Habe gelesen das Manjaro 0.8.8 den Stick automatisch erkennt was ich auch in dsmg sehen kann:
[    9.304494] em28xx: New device  WinTV HVR-930C @ 480 Mbps (2040:1605, interface 0, class 0)
[    9.304499] em28xx: Audio interface 0 found (Vendor Class)
[    9.304501] em28xx: Video interface 0 found: isoc
[    9.304503] em28xx: DVB interface 0 found: isoc
[    9.304675] em28xx: chip ID is em2884
[    9.374934] em2884 #0: i2c eeprom 0000: 26 00 01 00 02 0c 2a e5 f5 64 01 60 09 e5 f5 64
[    9.374947] em2884 #0: i2c eeprom 0010: 09 60 03 c2 c6 22 e5 f7 b4 03 13 e5 f6 b4 87 03
[    9.374956] em2884 #0: i2c eeprom 0020: 02 0b b8 e5 f6 b4 93 03 02 0a 74 c2 c6 22 c2 c6
[    9.374965] em2884 #0: i2c eeprom 0030: 22 00 60 00 d2 c6 7b 00 7a 00 79 23 22 90 05 9e
[    9.374974] em2884 #0: i2c eeprom 0040: 75 f0 25 e5 35 02 09 1d 25 e0 24 c6 f5 82 e4 34
[    9.374982] em2884 #0: i2c eeprom 0050: 06 f5 83 e4 93 22 e4 93 f5 36 e5 36 22 00 00 00
[    9.374991] em2884 #0: i2c eeprom 0060: 00 00 02 01 1a eb 67 95 40 20 05 16 70 13 6a 03
[    9.375000] em2884 #0: i2c eeprom 0070: 82 1e 6a 18 00 00 24 57 6e 07 29 00 00 00 00 00
[    9.375009] em2884 #0: i2c eeprom 0080: 00 00 00 00 4e 00 13 00 f0 10 02 82 82 00 00 00
[    9.375017] em2884 #0: i2c eeprom 0090: 5b 81 00 00 00 00 20 40 20 78 02 20 10 01 01 01
[    9.375026] em2884 #0: i2c eeprom 00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    9.375035] em2884 #0: i2c eeprom 00b0: c6 c5 00 00 84 00 00 a1 00 00 00 00 00 c2 00 00
[    9.375043] em2884 #0: i2c eeprom 00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 03
[    9.375052] em2884 #0: i2c eeprom 00d0: 34 00 30 00 33 00 31 00 33 00 30 00 35 00 39 00
[    9.375061] em2884 #0: i2c eeprom 00e0: 37 00 30 00 00 00 1e 03 57 00 69 00 6e 00 54 00
[    9.375070] em2884 #0: i2c eeprom 00f0: 56 00 20 00 48 00 56 00 52 00 2d 00 39 00 33 00
[    9.375079] em2884 #0: i2c eeprom 0100: ... (skipped)
[    9.375083] em2884 #0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x4cf00daa
[    9.375085] em2884 #0: EEPROM info:
[    9.375087] em2884 #0:    microcode start address = 0x0004, boot configuration = 0x01
[    9.382422] em2884 #0:    I2S audio, 3 sample rates
[    9.382426] em2884 #0:    500mA max power
[    9.382428] em2884 #0:    Table at offset 0x24, strings=0x1e82, 0x186a, 0x0000
[    9.382483] em2884 #0: Identified as Hauppauge WinTV HVR 930C (card=81)
[    9.383679] tveeprom 11-0050: Hauppauge model 16009, rev B1F0, serial# 4774130
[    9.383683] tveeprom 11-0050: MAC address is 00:0d:fe:48:d8:f2
[    9.383686] tveeprom 11-0050: tuner model is Xceive XC5000 (idx 150, type 76)
[    9.383689] tveeprom 11-0050: TV standards PAL(B/G) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xf4)
[    9.383692] tveeprom 11-0050: audio processor is unknown (idx 45)
[    9.383694] tveeprom 11-0050: decoder processor is unknown (idx 44)
[    9.383697] tveeprom 11-0050: has no radio, has IR receiver, has no IR transmitter
[    9.383803] em2884 #0: Config register raw data: 0x05
[    9.383808] em2884 #0: v4l2 driver version 0.2.0
[    9.389004] em2884 #0: V4L2 video device registered as video1
[    9.389008] em2884 #0: analog set to isoc mode.
[    9.389009] em2884 #0: dvb set to isoc mode.
[    9.389491] usbcore: registered new interface driver em28xx
[   11.372548] drxk: status = 0x439130d9
[   11.372554] drxk: detected a drx-3913k, spin A2, xtal 20.250 MHz
[   12.742179] DRXK driver version 0.9.4300
[   12.756554] drxk: frontend initialized.
[   12.846904] xc5000 11-0061: creating new instance
[   12.847425] xc5000: Successfully identified at address 0x61
[   12.847428] xc5000: Firmware has not been loaded previously
[   12.847433] DVB: registering new adapter (em2884 #0)
[   12.847440] usb 7-1: DVB: registering adapter 0 frontend 0 (DRXK DVB-C DVB-T)...
[   12.848402] em2884 #0: Successfully loaded em28xx-dvb
[   12.848407] Em28xx: Initialized (Em28xx dvb Extension) extension
[   13.160054] Registered IR keymap rc-hauppauge
[   13.160221] input: em28xx IR (em2884 #0) as /devices/pci0000:00/0000:00:1a.7/usb7/7-1/rc/rc0/input13
[   13.160300] rc0: em28xx IR (em2884 #0) as /devices/pci0000:00/0000:00:1a.7/usb7/7-1/rc/rc0
[   13.160810] Em28xx: Initialized (Em28xx Input Extension) extension
Auch der Senderscan in Ireland mit w_scan war erfolgreich, doch wenn ich Kaffeine oder VLC aufrufe um dort einen Senderscan durchzufueren wird mir in Kaffeine in den Einstellung unter Television der Stick als Device1 angezeigt doch wenn ich nach Sendern scannen will wird kein Device bei der Channelsuche angezeigt. In VLC  kann ich zwar das Device aussuchen doch es wird kein Scan ausgefuehrt und in der Playlist wird zwar ein Verzeichnis mit DVB angelegt doch es passiert weiter nichts.
Ich habe so das Gefuehl das der TV-Stick von den beiden Softwaren nicht angesprochen wird oder er nicht richtig geladen wird !?
Wenn einer eine Loesung fuer mich haette waehre ich dankbar, doch bitte erleuetere mir es bitte in Anfaengersprache da ich zwar mich mit Linux noch nicht so gut auskenne.
