Ja, funktioniert! Bruckner Sinfonie No.4
[root@manjaro sam]# audacious '
http://199.195.194.140:8160/stream2'
(bootstrap.c:60) [mowgli_init]: mowgli_init() is a deprecated function, provided only for backwards compatibility with Mowgli-1. You should remove it if you no longer support using Mowgli-1.
** (audacious:1206): WARNING **: Unable to connect to dbus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
(audacious:1206): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(audacious:1206): GLib-GObject-CRITICAL **: g_signal_emit_valist: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
