Autor Thema: [Testing Update] 2016-08-10 - Mate (from Arch), Vulkan, Texlive, Lumina  (Gelesen 571 mal)
Offline linuxkumpel
  • Held Mitglied
  • Dankeschön: 58 mal
  • "Sei klug und stell Dich dumm!"
  • Desktop: Xfce x86_64 4.12.4
  • Grafikkarte: Intel HD Graphics 4400
  • Kernel: 4.18 / 4.14
  • Prozessor: Intel Core i3-4010U
  • Skill: Durchschnitt
  • Zweig: testing (Xfce, Lxde)
https://forum.manjaro.org/t/testing-update-2016-08-10-mate-from-arch-vulkan-texlive-lumina/7170
Zitat
philmManjaro Team
Hi community,
this update is more or less the move back to Archlinux Mate-Upstream packages. It took a while for Arch to pick them up. Since upstream is again maintaining Mate, it makes not so much sense to do double work from our end.
TeXLive packages have been updated to the 2016 version. The most notable change is that the biber utility is now provided as a separate package. You can install it normally using pacman. Pacman hooks are now used in the TeXLive packages so the update will be less verbose than in past years.
Also we moved our Netbook-Kernel up a notch and updated it to v4.4 kernel series and Lumina-Desktop sees its first stable release.
Archlinux upstream fixes are now from: Wed Aug 10 07:20 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias2 to check these changes on a fresh install.
Kind regards,
Philip Müller and the Manjaro Development Team
Troubleshoots
GTK3
With this we updated Gnome and GTK to 3.20. This will break most of the themes, which will be fixed if and when their developers decide to update them. Some GTK 3.20-compliant themes are ready now - see further down this post.
The new default Manjaro GTK theme, which is GTK 3.20 compatible, is Vertex-Maia
You can install it with:
sudo pacman -Sy vertex-maia-themes vertex-maia-icon-theme xcursor-maia
KDE users should default to Maia theme:
sudo pacman -Sy maia-icon-theme gtk-theme-maia plasma5-themes-maia xcursor-maia
QT apps style with GTK - only needed for non-KDE desktop environments!
With QT 5.7 you need to install qt5-styleplugins and qt5ct and configure your system to have an unified look again.
ufw
If you have issues with ufw not working anymore, you have to copy your custom rules to a different folder. Do it like this:
sudo cp -v /usr/lib/ufw/user.rules.pacsave /etc/ufw/user.rules
sudo cp -v /usr/lib/ufw/user6.rules.pacsave /etc/ufw/user6.rules
steam
Steam might not work due incompatiblity of libgpg. You my try followed command to "fix" it:
find ~/.steam/root/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "libxcb.so*" -o -name "libgpg-error.so*" \) -print -delete
find ~/.local/share/Steam/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "libxcb.so*" -o -name "libgpg-error.so*" \) -print -delete
Reference: Archlinux wiki
Lenovo M 30-70 Manjaro 17.1.12 Hakoila Xfce | Netbook Packard Bell Dot's - Manjaro 17.1.12 Hakoila LXDE | Packard Bell Easynote TK 85 - Linux Lite 4.0 Xfce | ThinkPad T420s Pop!_OS | Dell Inspiron 11-3162 PeppermintOS Nine 9 | Asus EeePC 701 4 G - Peppermint OS | Dell Latitude E7240 - Windows 10   "Lieber mit Linux üben, als Microsoft eine Chance." EDV, Ende der Vernunft!
