Autor Thema: [Update] 2017-04-09 - OpenRC, Thunderbird, Kernels, Deepin, Mate  (Gelesen 335 mal)
Offline landtaipan
  • Vollwertiges Mitglied
  • Dankeschön: 36 mal
  • Desktop: xfce
  • Grafikkarte: nvidia
  • Grafikkartentreiber: free
  • Kernel: 4.14
  • Prozessor: Intel i7
  • Skill: Durchschnitt
  • Zweig: stable/testing
Zitat
philm - Manjaro Team
Hi community,
seems with the new mesa-stack we created some issues on some systems of yours. Also with the release of v17.0.1 we were able to bring some systems back to life. Others managed to fix their systems on their own. Well, sometimes changing some bigger in the system, even we have tested it thru and thru on several systems shows that some older systems sometimes have issues. This issue might be solved with the depreciation of i686 later this year.
We are currently thinking about i686 in general and if we should adopt Archlinux32 somehow. Let us know about your feelings about this matter.
For this update we have some new Kernels, updates to Mate and Deepin, lot of new stuff for our OpenRC fans and the latest Thunderbird.
Please test and give us feedback as usual
Current supported Kernels
    linux310 3.10.105
    linux312 3.12.72
    linux316 3.16.43
    linux318 3.18.48 [EOL]
    linux41 4.1.39
    linux44 4.4.60
    linux48 4.8.17 [EOL]
    linux49 4.9.21
    linux410 4.10.9
    linux411 4.11-rc2
    linux-RT-LTS 4.4.53_rt66
    linux-RT 4.9.20_rt16
Package Updates (Sun Apr 9 01:52:54 CEST 2017)
    testing community i686: 395 new and 383 removed package(s)
    testing community x86_64: 415 new and 402 removed package(s)
    testing core i686: 28 new and 26 removed package(s)
    testing core x86_64: 28 new and 26 removed package(s)
    testing extra i686: 130 new and 120 removed package(s)
    testing extra x86_64: 130 new and 120 removed package(s)
    testing multilib x86_64: 1 new and 1 removed package(s)
Offline linuxkumpel
  • Held Mitglied
  • Dankeschön: 42 mal
  • "Sei klug und stell Dich dumm!"
  • Desktop: Xfce x86_64 4.12.4
  • Grafikkarte: Intel HD Graphics 4400
  • Kernel: 4.14 / 4.9
  • Prozessor: Intel Core i3-4010U
  • Zweig: testing
Re: [Update] 2017-04-09 - OpenRC, Thunderbird, Kernels, Deepin, Mate
« Antwort #1 am: 09. April 2017, 18:07:35 »
Hinweis, wer Thunderbird mit Lightning nutzt, vom Update ausschließen. Lightning ist noch nicht angepasst.
https://forum.manjaro.org/t/testing-update-2017-04-09-openrc-thunderbird-kernels-deepin-mate/21445/3
Suche nämlich gerade nach einer Lösung.
Lenovo M 30-70 Manjaro 17.1.2 Hakoila Xfce - Kernel: x86_64 Linux 4.14.14-1 MANJARO, Intel Core i3-4010U, Intel HD Graphics 4400 | Packard Bell Easynote F4085 - Linux Lite, PeppermintOS, Pop!_OS | Netbook Packard Bell Dot's - Manjaro 17.1.2 Hakoila LXDE | Dell Inspiron 11-3162 PeppermintOS 8 | Asus EeePC 701 4 G - Peppermint OS | Dell Latitude E7240 - Windows 10   "Lieber mit Linux üben, als Microsoft eine Chance."
Offline linuxkumpel
  • Held Mitglied
  • Zweig: testing
« Antwort #2 am: 09. April 2017, 19:51:30 »
Habe ausgeführt
sudo downgrade thunderbird
und danach Sprachpaket angepasst. Geht bestimmt auch per Terminal, hatte ich bloß nicht griffbereit.
GypsyWolve
  • Gast
« Antwort #3 am: 10. April 2017, 01:16:11 »
====> OpenRC und networkmanager
Kam in die Schleife
:: Replace udev-openrc with community/eudev-openrc? [Y/n]
resolving dependencies...
warning: removing 'device-mapper' from target list because it conflicts with 'device-mapper-nosystemd'
:: dbus-elogind and dbus-x11 are in conflict (libdbus). Remove dbus-x11? [y/N] y
:: device-mapper-nosystemd and device-mapper are in conflict. Remove device-mapper? [y/N] y
:: dhcpcd-nosystemd and dhcpcd are in conflict. Remove dhcpcd? [y/N] y
:: networkmanager-openrc and networkmanager-consolekit are in conflict. Remove networkmanager-consolekit? [y/N] y
:: rpcbind-nosystemd and rpcbind are in conflict. Remove rpcbind? [y/N] y
:: networkmanager-openrc: requires networkmanager
Abhilfe
pacman -S networkmanager
Hatte noch pm-utils (Installation hat fast 4 Jahre auf den Buckel) der sollte im Vorwege allerdings auch entfernt werden
pacman -R pm-utils
Danach lief das update incl Neustart ohne probs durch
GW
Folgende Mitglieder bedankten sich: gosia
Offline thommy
  • Dankeschön: 12 mal
  • Desktop: xfce
  • Kernel: 4.14
  • Prozessor: Intel i5
  • Zweig: stable
« Antwort #4 am: 12. April 2017, 06:23:04 »
Bei mir war das update kein Problem.
