Autor Thema: [Update] Pale Moon: 27.4.0 (2017-07-12)  (Gelesen 2114 mal)
Offline virtual-dev
  • Sr. Mitglied
  • Dankeschön: 692 mal
  • Desktop: Xfce4
  • Grafikkarte: Intel HD Graphics 630
  • Grafikkartentreiber: free
  • Kernel: 4.19 LTS
  • Prozessor: i7-7700HQ
  • Skill: Fortgeschritten
  • Zweig: *
« am: 12. Juli 2017, 18:44:17 »
Zitat
Pale Moon: Release notes
27.4.0 (2017-07-12)
This is a major update to straighten out most of the media streaming issues, as well as adding the necessary enhancements, bugfixes and security fixes to the browser.
Changes/fixes:
    Completely re-worked the Media Source Extensions code to make it spec compliant, and asynchronous as per specification for MSE with MP4. This should fix playback problems on YouTube, Twitch, Vimeo and other sites that previously had some issues. A massive thank you to Travis for his tireless work on making this happen!
    Please note that MSE+WebM (disabled by default) is not using this new code yet (planned for the next release), and as such there is a temporary set of things to keep in mind if you don't use default settings:
        If you have previously enabled MSE+WebM, this setting will be reset when you update to avoid conflicting settings with the updated MSE code.
        We've added an extra setting in Options to disable the updated MSE code (asynchronous use) in case you need to use WebM or are otherwise having issues with the updated code (please let us know in that case).
        Once again, the MSE+WebM and Asynchronous MSE use are currently mutually exclusive. You can have one or the other, not both, until we sort out the code for WebM. To enable MSE+WebM you will first have to disable Asynchronouse MSE in settings (otherwise the WebM setting will be greyed out and disabled).
    Added a control in options/preferences for HSTS and HPKP usage.
    Changed HTML bookmark exports to write CRLF line endings to the file on Windows.
    Leveraged multi-core rendering for libVPX (VP8/VP9 WebM decoding).
    Fixed some issues accessing DeviantArt (useragent-sniffing).
    Aligned CSS text-align with the spec.
    Added a recovery module for browser initialization issues (e.g. when using a wrong language pack).
    Fixed spurious console errors for XHR requests with certain http response codes.
    Enabled v-sync aligned refresh for a smoother scrolling experience.
    Removed support for CSS XP-theme media queries.
    Improved console error reporting.
    Fixed resetting toolbars and controls from the safe mode dialog.
    Fixed bookmark recovery option from the safe mode dialog.
    Fixed innerText getters for display:none elements.
    Fixed a GL buffer crash that might occur with certain combinations of drivers and hardware.
    Added some more details to about:support.
    Fixed a potential crash when the last audio device is removed during playback.
    Fixed a crash on about:support when windowless browsers are created.
    Updated <select> elements to blank if the actively set value doesn't match any of the options.
    Updated the interpretation of 2-digit years in date formats to match other browsers:
    0-49 = 2000-2049, 50-99 = 1950-1999.
    Added "q" units to CSS (quarter of a millimeter).
    Added .origin property to blobs.
    Fixed several minor layout issues.
    Fixed disabled HTML elements not producing the proper JS events.
    Implemented web content handler blacklist according to the spec, allowing more than feeds to be registered.
    Fixed a spec compliance issue with execCommand() on HTML elements.
    Fixed a problem with table borders being drawn uneven or being omitted when zooming the page.
    Added devtools "filter URLs" option in the network panel.
    Added visual sorting options to the Network inspector.
    Added importing of login data from Chrome profiles on Windows (Chrome has to be closed first).
    Added importing of tags from bookmark export files (HTML format).
    Updated usage of SourceMap headers with the updated spec (SourceMap header, keeping X-SourceMap as a fallback).
    Fixed several cases of wrongly-used negations in JS modules.
    Added the auxclick mouse event.
    Added a control to not autoplay video unless it is in view (media.block-play-until-visible).
    Updated the Graphite font library to 1.3.10.
    Updated how image and media elements respond to window size changes (responsive design).
    Added parsing and use of rotation meta data in video.
    Fixed several crashes in a number of modules.
    Fixed performance regression for scaling large vector images (e.g. MSIE Chalkboard test) \o/
    Fixed some issues with notification icons.
    Fixed some internal errors with live bookmarks.
    Updated SQLite to 3.19.3.
    Fixed several reported issues with devtools (cli-cookies, cli help, copying cURL, inspecting SVGs, element size calculations, etc.)
    Fixed an issue where a server response was allowed to override add-ons' specified version ranges even for add-ons that have strict compatibility (e.g. themes, language packs).
Security fixes:
    Removed preloading of HPKP hosts and enabled HPKP header enforcement.
    Added support for TLS 1.3, the up-next secure connection protocol.
    Fixed an issue with TLS 1.3 not supporting renegotiation by design.
    Relaxed some restrictions for CSP to temporarily work around web compatibility issues with the CSP-3 deprecated `child-src` directive.
    Updated NSS to 3.28.5.1-PM to address some security issues.
    Updated the installer selfextractor module to address unsafe loading of libraries.
    Changed the way certain resources are included to reduce effectiveness of some common fingerprinting techniques. (e.g. browserleaks.org)
    Fixed a regression in the display of security information in the page info dialog for insecure content.
    Fixed two potential issues with allocating memory for video. DiD
    Fixed a potential issue with the network prediction algorithm. DiD
    Restricted the use of Aspirational scripts in IDNs to prevent domain spoofing, in anticipation of the UAX#31 update making this official.
    Prevented a Mac font specific issue that could be abused for domain spoofing (CVE-2017-7763)
    Fixed several potentially exploitable crashes. (CVE-2017-7751) (CVE-2017-7757) and some that do not have a CVE designation.
Link
Folgende Mitglieder bedankten sich: FZR
Offline charly700
  • Sr. Mitglied
  • Dankeschön: 5 mal
  • Desktop: XFCE
  • Grafikkarte: PC: NVIDIA GeForce 930M
  • Kernel: immer den Neuesten und einen LTS-Kernel
  • Prozessor: Core i5-6200U
  • Skill: Durchschnitt
  • Zweig: stable
Re: [Update] Pale Moon: 27.4.0 (2017-07-12)
« Antwort #1 am: 12. Juli 2017, 20:11:55 »
pminstall.sh funktioniert bei mir nicht, was muss ich machen bzw beachten das es geht?
Edit: Er sagt das Palemoon bereits installiert ist und erst entfernt werden muss. Habe ihn aber über pamac deinstalliert.
Muss auch das Profil gelöscht werden?
« Letzte Änderung: 12. Juli 2017, 20:15:51 von charly700 »
Offline charly700
  • Sr. Mitglied
  • Dankeschön: 5 mal
  • Desktop: XFCE
  • Zweig: stable
« Antwort #2 am: 12. Juli 2017, 23:18:52 »
Danke. Das werde ich dann mal versuchen. Habe aber Heute leider keine Zeit mehr.
Offline charly700
  • Sr. Mitglied
  • Dankeschön: 5 mal
  • Desktop: XFCE
  • Zweig: stable
« Antwort #3 am: 15. Juli 2017, 00:49:34 »
Dann müssen noch Reste auf der Platte sein.
Gehe mal in ein Terminal und lösche noch mal mit:
sudo pacman -Rs palemoon
Dann kontrolliere mit:
yaourt -Ss palemoonob alles weg ist, auch das Sprachpaket.
Dann kannst du noch mit:
sudo updatedb && locate palemoonschauen, ob noch Reste auf der Platte sind.
Danach schauen, ob du das aktuellste Install-script
runter geladen hast:
http://linux.palemoon.org/download/installer/
Der erste Befehl ergibt: Fehler: Ziel nicht gefunden: palemoon
Der zweite: [charly@charly-pc ~]$ yaourt -Ss palemoon
community/ff-theme-util 1.4-1
    Utility to autocreate matching Firefox and Palemoon theme symlinks
community/palemoon-bin 27.3.0-1
    Open source web browser based on Firefox focusing on efficiency.
community/palemoon-i18n-ar 26.4-1
    Arabic language pack for Palemoon
community/palemoon-i18n-cs 27.2.1-1
    Czech language pack for Palemoon
community/palemoon-i18n-da 26.4-1
    Danish language pack for Palemoon
community/palemoon-i18n-de 27.2.1-1
    German language pack for Palemoon
community/palemoon-i18n-el 26.4-1
    Greek (Modern) language pack for Palemoon
community/palemoon-i18n-en-gb 27.2.1-1
    English (U.K.) language pack for Palemoon
community/palemoon-i18n-es-ar 27.2.1-1
    Spanish (Argentina) language pack for Palemoon
community/palemoon-i18n-es-es 27.2.1-1
    Spanish (Spain) language pack for Palemoon
community/palemoon-i18n-es-mx 27.2.1-1
    Spanish (Mexico) language pack for Palemoon
community/palemoon-i18n-fi 26.4-1
    Finnish language pack for Palemoon
community/palemoon-i18n-fr 27.2.1-1
    French language pack for Palemoon
community/palemoon-i18n-gl-es 26.4-1
    Galician (Spain) language pack for Palemoon
community/palemoon-i18n-hr 26.4-1
    Croatian language pack for Palemoon
community/palemoon-i18n-hu 27.2.1-1
    Hungarian language pack for Palemoon
community/palemoon-i18n-is 26.4-1
    Icelandic language pack for Palemoon
community/palemoon-i18n-it 27.2.1-1
    Italian language pack for Palemoon
community/palemoon-i18n-ja 27.2.1-1
    Japanese language pack for Palemoon
community/palemoon-i18n-kn 27.0.0-0.3
    Kannada (India) language pack for Palemoon
community/palemoon-i18n-ko 27.2.1-1
    Korean language pack for Palemoon
community/palemoon-i18n-nl 26.4-1
    Dutch language pack for Palemoon
community/palemoon-i18n-pl 27.2.1-1
    Polish language pack for Palemoon
community/palemoon-i18n-pt-br 27.0.0-0.3
    Portuguese (Brazil) language pack for Palemoon
community/palemoon-i18n-pt-pt 27.0.0-0.4
    Portuguese (Portugal) language pack for Palemoon
community/palemoon-i18n-ro 26.4-1
    Romanian/Moldavian language pack for Palemoon
community/palemoon-i18n-ru 27.2.1-1
    Russian language pack for Palemoon
community/palemoon-i18n-sk 26.4-1
    Slovak language pack for Palemoon
community/palemoon-i18n-sl 26.4-1
    Slovenian language pack for Palemoon
community/palemoon-i18n-sr 26.4-1
    Serbian language pack for Palemoon
community/palemoon-i18n-sv-se 26.4-1
    Swedish language pack for Palemoon
community/palemoon-i18n-tr 26.4-1
    Turkish language pack for Palemoon
community/palemoon-i18n-vi 27.0.0-0.3
    Vietnamese language pack for Palemoon
community/palemoon-i18n-zh-cn 27.2.1-1
    Chinese (Simplified) language pack for Palemoon
community/palemoon-i18n-zh-tw 26.4-1
    Chinese (Traditional) language pack for Palemoon
aur/arch-palemoon-search 0.1-2 (14) (0,29)
    Pale Moon Arch search engines (AUR, Pkgs, BBS, Wiki, etc.)
aur/palemoon 27.4.0-2 (102) (5,28)
aur/palemoon-26 26.5.0-3 (2) (0,31)
    Pale Moon web browser, old version 26 (still with the jetpack SDK addon
    technology, but not maintained anymore). Unofficial New Moon-branding.
aur/palemoon-atom-bin 26.5.0-1 (Out of Date) (10) (0,09)
    Open source web browser based on Firefox focusing on efficiency - i686
    Intel Atom optimised version
aur/palemoon-bin 27.4.0-1 (142) (3,74)
aur/palemoon-extension-shumway 0.11.617-1 (9) (0,00)
    Mozilla HTML5 implementation of flash for Palemoon
aur/palemoon-git 27.2.0a1+dfe35096e-1 (3) (0,59)
    Open source web browser based on Firefox focusing on efficiency (git
    version)
aur/palemoon-i18n-common 27.0-2 (1) (0,39)
    Common data for Pale Moon language packs
aur/palemoon-i18n-cs 27.3.1-1 (1) (0,39)
    Czech language pack for Pale Moon browser
aur/palemoon-i18n-de 27.3.1-1 (1) (0,39)
    German language pack for Pale Moon browser
aur/palemoon-i18n-default 27.0-3 (24) (0,02)
    Pale Moon language pack for system active language.
aur/palemoon-i18n-en-gb 27.3.1-1 (1) (0,39)
    English British language pack for Pale Moon browser
aur/palemoon-i18n-es-ar 27.3.1-1 (1) (0,39)
    Spanish (Argentina) language pack for Pale Moon browser
aur/palemoon-i18n-es-es 27.3.1-1 (1) (0,39)
    Spanish (Spain) language pack for Pale Moon browser
aur/palemoon-i18n-es-mx 27.3.1-1 (1) (0,39)
    Spanish (Mexico) language pack for Pale Moon browser
aur/palemoon-i18n-fr 27.3.1-1 (Out of Date) (1) (0,39)
    French language pack for Pale Moon browser
aur/palemoon-i18n-hu 27.3.1-1 (1) (0,39)
    Hungarian language pack for Pale Moon browser
aur/palemoon-i18n-it 27.3.1-1 (1) (0,39)
    Italian language pack for Pale Moon browser
aur/palemoon-i18n-ja 27.3.1-1 (1) (0,39)
    Japanese language pack for Pale Moon browser
aur/palemoon-i18n-ko 27.3.1-1 (1) (0,39)
    Korean language pack for Pale Moon browser
aur/palemoon-i18n-pl 27.3.1-1 (1) (0,39)
    Polish language pack for Pale Moon browser
aur/palemoon-i18n-ru 27.3.1-1 (1) (0,39)
    Russian language pack for Pale Moon browser
aur/palemoon-i18n-zh-cn 27.3.1-1 (1) (0,39)
    Chinese (Simplified) language pack for Pale Moon browser
Und der dritte: [charly@charly-pc ~]$ sudo updatedb && locate palemoon
/home/charly/.moonchild productions.bak/pale moon/mv09cl9c.default/extensions/adblocklatitude@addons.palemoon.org.xpi
/home/charly/.moonchild productions.bak/pale moon/mv09cl9c.default/extensions/commander@palemoon.org.xpi
/home/charly/.moonchild productions.bak/pale moon/mv09cl9c.default/extensions/langpack-de@palemoon.org.xpi
/home/charly/.moonchild productions.bak/pale moon/mv09cl9c.default/extensions/pm-localeswitch@palemoon.org.xpi
/usr/lib/palemoon
/usr/lib/palemoon/distribution
/usr/lib/palemoon/distribution/distribution.ini
/usr/share/icons/Vertex-Maia/apps/48x48/apps/palemoon.svg
/usr/share/icons/Vertex-Maia/apps/scalable/palemoon.svg
Was kann ich da machen? Mit dem aktuellen Installscript läst sich Palemoon noch nicht installieren.
Habe auch noch Seamonkey installiert. Soll ich den auch mal deinstallieren?
« Letzte Änderung: 15. Juli 2017, 00:51:14 von charly700 »
Offline charly700
  • Sr. Mitglied
  • Dankeschön: 5 mal
  • Desktop: XFCE
  • Zweig: stable
« Antwort #4 am: 15. Juli 2017, 02:47:19 »
Danke. Hat geklappt. So bekommt man den aktuellen Palemoon am schnellsten.
Offline Ahnungsloser
  • Held Mitglied
  • Dankeschön: 43 mal
  • Desktop: KDE Plasma 5.14.5 - OpenRC
  • Grafikkarte: Intel 3rd Gen Core processor Graphics Controller | NVIDIA GK208M [GeForce GT 720M]
  • Kernel: 4.20.2-artix1-1-ARTIX
  • Prozessor: Intel Core i3-3217U
  • Skill: Anfänger
  • Zweig: stable
« Antwort #5 am: 15. Juli 2017, 06:06:16 »
Das Pale Moon Update 27.4.0 ist mittlerweile im testing angekommen.
Wird also sicherlich in Kürze auch im stable landen.
Im neuen Forum unter dem Nick "Roberto" :)
Offline FZR
  • Vollwertiges Mitglied
  • Dankeschön: 6 mal
  • Desktop: xfce4
  • Grafikkarte: Nvidia GTX 1080 Ti
  • Kernel: 4.19
  • Prozessor: AMD Ryzen 1900X
  • Zweig: Artix
« Antwort #6 am: 15. Juli 2017, 06:51:00 »
Klappt bei mir mit dem script seit ewigen Zeiten 1a.
Sprache ist inzwischen als Plugin immer mit drin und
wird automatisch mit upgedatet.
Server OS: Devuan 2.0
Offline tetzlaff
  • Dankeschön: 15 mal
  • Kernel: 4.20
  • Prozessor: AMD T1090
  • Zweig: stable
« Antwort #7 am: 15. Juli 2017, 18:49:25 »
Bei mir funktioniert das mit dem script auch völlig einfach und problemlos.
Manjaro, Artix-Linux, Devuan
