Autor Thema: New slic3r prusa edition and first layer  (Gelesen 1057 mal)
Offline nickyminaj
  • Neuling
  • Skill: Anfänger
« am: 20. Februar 2018, 10:33:46 »
Hi,
I'm using the last slic3r prusa edition 1.31.6
I've noticed that compared to the previous version,the first layer is now 0.2mm (it was 0.15mm before).
So I adjusted my live Z adjust according to this new value (I'm using my own square calibration gcode). When I slice my own STL files, they are all sliced with 0.2mm value for this first layer. Everything prints correctly.
But I also want to be able to print the Gcodes files from prusa, and the problem is that when I look at the Gcode provided with the drivers 1.7.5, the first layer is still 0.15mm. Even the V2 calibration is configured with 0.15mm. So I think if I try to print those Gcodes, there will be a bad first layer (it's a 50micron gap)?
Am I missing something or should I readjust live Z adjust each time I'm printing my own files or prusa files ?
Any idea?
Please help.
Thanks!
I didn't find the right solution from the Internet.
References
https://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/new-slic3r-prusa-edition-and-first-layer-t2516.html
Explainer Video studio
