Autor Thema: [Update] 2018-07-22 - Kernels, KDE, Gnome, Deepin, Mesa, Browsers, PHP  (Gelesen 1338 mal)
Offline virtual-dev
  • Sr. Mitglied
  • Dankeschön: 692 mal
  • Desktop: Xfce4
  • Grafikkarte: Intel HD Graphics 630
  • Grafikkartentreiber: free
  • Kernel: 4.19 LTS
  • Prozessor: i7-7700HQ
  • Skill: Fortgeschritten
  • Zweig: *
Zitat
philm - Manjaro Team
Hi community,
Welcome to another stable update. So what do we have with this one?
    Pamac got an enhanced cli mode
    Mesa got updated to v18.1.4 which brings fixes for radeon and intel
    we added the latest kernels
    updated some of our themes
    added some more patches and tweaks to GTK3-Classic
    Virtualbox got updated to v5.2.16
    we added the latest point-releases ([1][2]) of PulseAudio v12 series
    KDE frameworks got updated to v5.48.0
    KDE got updated with Plasma and Apps
    added some more Cinnamon, Gnome and Deepin packages
    Stefano managed to add our new plasma5-theme-adaptabreath theme for KDE
    we worked mostly on our profile-settings and themes
    we updated Palemoon and Firefox browsers
    php got updated
    python and haskell updates/rebuilds.
We hope with all these changes Manjaro to be more efficient for you all.
If you are curious about the latest state of development for the upcoming Manjaro-Illyria 18.0 release,
you now have the opportunity to download a beta-build of Manjaro-Xfce 18.0 including the latest
xfce-gtk3 packages aswell as our most recent styling efforts:
Our KDE fans may try our beta-build with the latest KDE v5.13 instead.
Latest information about the intel-cpu-bug risk and our efforts can be found here.
Current supported Kernels
    linux316 3.16.57
    linux318 3.18.115 [EOL]
    linux41 4.1.52 [EOL]
    linux44 4.4.141
    linux49 4.9.113
    linux414 4.14.56
    linux415 4.15.18 [EOL]
    linux416 4.16.18 [EOL]
    linux417 4.17.7
    linux418 4.18-rc5
    linux414-rt 4.14.52_rt34
    linux416-rt 4.16.18_rt10
Package Updates (Sat Jul 21 07:13:46 CEST 2018)
    stable community x86_64: 883 new and 875 removed package(s)
    stable core x86_64: 28 new and 28 removed package(s)
    stable extra x86_64: 729 new and 774 removed package(s)
    stable multilib x86_64: 28 new and 26 removed package(s)
A detailed list of all package changes may be reviewed hier
Offline leesrott
  • Sr. Mitglied
  • Dankeschön: 9 mal
  • Desktop: i3
  • Grafikkarte: Intel 3rd Gen Core processor Graphics Controller
  • Kernel: Linux 4.4
  • Prozessor: intel core i5
  • Skill: Durchschnitt
  • Zweig: stable
Grundsätzlich ist alles gut durchgelaufen. Allerdings sind bei i3 die Buttons für Netzwerk, Pamac, Lautstärke und Bluetooth irgendwie grau hinterlegt. Ob das mit dem Update von gtk classic zusammenhängt? Außerdem nimm pavucontrol nach dem Start immer noch keine Verbindung zu pulseaudio auf. Vielleicht gibt es noch weitere i3 Nutzer. Vielleicht weiß jemand Näheres? Danke!
Offline SpiritOfTux
  • Held Mitglied
  • Dankeschön: 183 mal
  • Desktop: KDE Plasma, Deepin
  • Grafikkartentreiber: On: NB intel/nvidia, HTPC nvidia, PowerWorkStation nvidia
  • Kernel: 4.14.y LTS, 4.9.y LTS,
  • Zweig: stable 17.1.y on PowerWorkStation, NB, HTPC, Desktop:s: Testing or Unstable only VM
Öffne Konsole/Terminal, teste dann
pulseaudio --start
Öffne 2.Konsole/2.Terminal, teste dann
pavucontrol
Wenn es klappt gibt es sicherlich die Möglichkeit dies in die Autostart ein zu binden.
Offline leesrott
  • Sr. Mitglied
  • Dankeschön: 9 mal
  • Desktop: i3
  • Kernel: Linux 4.4
  • Zweig: stable
Hab ich bereits in der i3/conf so eingebunden.
exec --no-startup-id pulseaudio --start
Offline SpiritOfTux
  • Held Mitglied
OK
sudo systemctl stop pulseaudio.service
sudo systemctl status pulseaudio.service
rm -r ~/.config/pulse.cookie
sudo systemctl start pulseaudio.service
Offline leesrott
  • Sr. Mitglied
  • Dankeschön: 9 mal
  • Desktop: i3
  • Kernel: Linux 4.4
  • Zweig: stable
~]$ sudo systemctl stop pulseaudio.service
Failed to stop pulseaudio.service: Unit pulseaudio.service not loaded.
Die Datei pulse.cookie existiert in meinem Home-Verzeichnis gar nicht.
Was funktioniert ist, wenn ich nach dem Hochfahren des Rechners
pulseaudio --kill
und danach
pulseaudio --start
ausführe. Aber warum funktioniert der Start beim Hochfahren nicht ordnungsgemäß?
Offline SpiritOfTux
  • Held Mitglied
Testen wir
sudo systemctl enable pulseaudio.service     <<=== Unit pulseaudio.service aktiviern.
sudo systemctl start pulseaudio.service        <<=== Unit pulseaudio.service starten.
reboot
sudo systemctl status pulseaudio.service     <<===  Unit pulseaudio.service aktiv ??.
Offline leesrott
  • Sr. Mitglied
  • Dankeschön: 9 mal
  • Desktop: i3
  • Kernel: Linux 4.4
  • Zweig: stable
~]$ sudo systemctl enable pulseaudio.service
[sudo] Passwort:
Failed to enable unit: Unit file pulseaudio.service does not exist.
Hm ... ich bin verwirrt.
Offline SpiritOfTux
  • Held Mitglied
[sudo] Passwort:
Habe die ISO 17.1.11.1 gezogen, VM-i3 erstellt, nach diesem Stand ist der ALSA der Standard, rechts unten auf das Lautsprecher-Symbol gehen,
rechtsKlich ==> Einstellungen ==> jetzt kann die SoundCard + Kanal gewählt werden.
Öffne ein Terminal,wir prüfen die Kanäle,
alsamixer
mit dem kleinem M (Tastatur) wird der Status mm (Mute) auf gehoben.
Wenn PulseAudio gewünscht wird, hier die Packages
Zitat
alsa-firmware         ALSA firmware package, sollte installiert sein
alsa-lib            An alternative implementation of Linux sound support, sollte installiert sein
alsa-plugins         Extra alsa plugins, sollte installiert sein
alsa-utils            An alternative implementation of Linux sound support, sollte installiert sein
manjaro-alsa         Manjaro ALSA support (Meta-PKG), sollte installiert sein
manjaro-pulse         Manjaro Pulseaudio support (Meta-PKG)
pulseaudio            A featureful, general-purpose sound server
pulseaudio-alsa         ALSA Configuration for PulseAudio
pulseaudio-bluetooth   Bluetooth support for PulseAudio
pulseaudio-ctl         Control pulseaudio volume from the shell or mapped to keyboard shortcuts.
pulseaudio-zeroconf      Zeroconf support for PulseAudio
