Autor Thema: Fehlermeldung beim Booten (neuer PC)  (Gelesen 1336 mal)
Offline rambler
  • Vollwertiges Mitglied
  • Desktop: xfce
  • Grafikkarte: nvidia 9200M GS
  • Grafikkartentreiber: nouveau
  • Kernel: 4.19.2-1
  • Prozessor: Intel Core Duo
  • Skill: Anfänger
  • Zweig: stable
« am: 30. Juli 2018, 17:52:50 »
Hallo,
sollte ich das ignorieren? Erscheint beim Bootvorgang:
dmesg...
[    0.332389] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.332483] pci 0000:00:1c.7: PCI bridge to [bus 02]
[    0.332486] pci 0000:00:1c.7:   bridge window [io  0x3000-0x3fff]
[    0.332489] pci 0000:00:1c.7:   bridge window [mem 0xa1100000-0xa11fffff]
[    0.333626] ACPI Exception: AE_NOT_FOUND, Evaluating _PRS (20170728/pci_link-176)
[    0.333635] ACPI Exception: AE_NOT_FOUND, Evaluating _PRS (20170728/pci_link-176)
[    0.333643] ACPI Exception: AE_NOT_FOUND, Evaluating _PRS (20170728/pci_link-176)
[    0.333650] ACPI Exception: AE_NOT_FOUND, Evaluating _PRS (20170728/pci_link-176)
[    0.333657] ACPI Exception: AE_NOT_FOUND, Evaluating _PRS (20170728/pci_link-176)
[    0.333664] ACPI Exception: AE_NOT_FOUND, Evaluating _PRS (20170728/pci_link-176)
[    0.333671] ACPI Exception: AE_NOT_FOUND, Evaluating _PRS (20170728/pci_link-176)
[    0.333678] ACPI Exception: AE_NOT_FOUND, Evaluating _PRS (20170728/pci_link-176)
[    0.334165] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.334165] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.334165] pci 0000:00:02.0: vgaarb: bridge control possible
falls ja, was macht man da?
Offline SpiritOfTux
  • Held Mitglied
  • Dankeschön: 183 mal
  • Desktop: KDE Plasma, Deepin
  • Grafikkartentreiber: On: NB intel/nvidia, HTPC nvidia, PowerWorkStation nvidia
  • Kernel: 4.14.y LTS, 4.9.y LTS,
  • Skill: Fortgeschritten
  • Zweig: stable 17.1.y on PowerWorkStation, NB, HTPC, Desktop:s: Testing or Unstable only VM
Re: Fehlermeldung beim Booten (neuer PC)
« Antwort #1 am: 30. Juli 2018, 18:05:33 »
Wird hier der/die VM Manager Parallels Desktop verwendet ??
Offline rambler
  • Desktop: xfce
  • Kernel: 4.19.2-1
  • Skill: Anfänger
  • Zweig: stable
« Antwort #2 am: 01. August 2018, 16:31:31 »
nein, nix VM oder Parallel..., alles einfach mit xfce...  ???
Offline SpiritOfTux
  • Held Mitglied
« Antwort #3 am: 01. August 2018, 20:03:37 »
War nicht ganz einfach dies ein zu grenzen
20170728 ===>    ACPICA kernel-resident subsystem
            Kompatibilität mit anderen ACPI-Implementierungen und unterstützt vorhandene
            Firmware
In der neuesten Intel-Hardware werden die IRQs nach dem BIOS nicht mehr konfigurierbar
initialisiert sie sind in PEI-Phase und _PRS-Objekte nicht mehr enthalten ASL.
Angeben eines _PRS-Objekts "in ACPI-Spezifikation. Als Ergebnis Fehlermeldungen
"ACPI-Ausnahme: AE_NOT_FOUND, Evaluieren von _PRS"
Zeige deine Hardware inxi -Fxzc0 --usb
Läuft auf dem Rechner der Neuste Kernel 4.17.y ??
wenn ja installiere den 4.14.y siehe dann nach ob diese ACPI - Meldungen etc. erscheinen
« Letzte Änderung: 01. August 2018, 20:08:41 von SpiritOfTux »
Offline rambler
  • Desktop: xfce
  • Kernel: 4.19.2-1
  • Skill: Anfänger
  • Zweig: stable
« Antwort #4 am: 01. August 2018, 20:37:48 »
du könntest ebensogut russisch reden  :-[ ;)
bei mir läuft Kernel 4.14.54-1
inxi -Fxzc0 --usb
  Host: r-pc Kernel: 4.14.54-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 8.1.1 Desktop: N/A Distro: Manjaro Linux 17.1.11 Hakoila
  Type: Desktop Mobo: ASUSTeK model: PRIME H310M-A v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 0401 date: 03/19/2018
  Topology: 6-Core model: Intel Core i5-8400 bits: 64 type: MCP
  arch: Skylake rev: A L2 cache: 9216 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 33708
  Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800 5: 800 6: 800
  Card-1: Intel driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: N/A driver: intel unloaded: fbdev,modesetting,vesa
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2)
  v: 4.5 Mesa 18.1.3 direct render: Yes
  Card-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel v: kernel
  bus ID: 00:1f.3
  Sound Server: ALSA v: k4.14.54-1-MANJARO
  Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8168 v: 8.045.08-NAPI port: 3000 bus ID: 02:00.0
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  HDD Total Size: 463.36 GiB used: 13.96 GiB (3.0%)
  ID-1: /dev/sda model: SMI DISK size: 463.36 GiB
  ID-1: / size: 446.13 GiB used: 13.96 GiB (3.1%) fs: ext4 dev: /dev/sda2
  ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
  Hub: 1:1 usb: 2.0 type: Full speed (or root) hub
  Device-1: MosArt bus ID: 1:2 usb: 1.1 type: Mouse
  Device-2: Logitech Corded Keyboard K280e bus ID: 1:3 usb: 1.1
  type: Keyboard
  Device-3: Alcor Micro AU6477 Card Reader Controller bus ID: 1:4 usb: 2.0
  type: Mass Storage
  Hub: 2:1 usb: 3.1 type: Full speed (or root) hub
  System Temperatures: cpu: 27.8 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 179 Uptime: 4m Memory: 7.64 GiB used: 1.01 GiB (13.2%)
  Init: systemd Compilers: gcc: 8.1.1 Shell: bash v: 4.4.23 inxi: 3.0.12
Offline SpiritOfTux
  • Held Mitglied
« Antwort #5 am: 02. August 2018, 12:23:36 »
Dein BIOS
enthält nicht die Informationen die hier
als Status gemeldet werden.
