Autor Thema: [Update] 2018-08-06 - Kernels, Plasma, Jade, Deepin, Firefox, Haskell  (Gelesen 2011 mal)
Offline landtaipan
  • Vollwertiges Mitglied
  • Dankeschön: 48 mal
  • Desktop: xfce
  • Grafikkarte: nvidia
  • Grafikkartentreiber: free
  • Kernel: 4.19
  • Prozessor: Intel i7
  • Skill: Durchschnitt
  • Zweig: stable/testing
Zitat
philm - Manjaro Team
Hi community,
Welcome to another stable update. So what do we have with this one?
    we updated most of our kernels
    Bernhard updated our RT-Kernelseries v4.14
    KDE Plasma got updated to 5.13.4
    firefox got a new development release
    networkmanager got its point-release
    deepin and xfce-gtk3 got new package updates
    some fixes to pulseaudio
    our Jade-Desktop packages switched to stable versions
    Stefano updated our Adapta Themes
    added Mesa 18.1.5
    we updated pacman to 5.1.1
    wine got updated to 3.13
    pushed out a new linux-firmware to support more AMD-GPUs
    the usual python/haskell rebuilds/updates
We hope with all these changes Manjaro to be more efficient for you all.
Currently we are working on a new Manjaro-Hardware project, the Bladebook Fall 2018. It will be powered
by Manjaro KDE v18.0 and the latest Intel Apollo Lake Quad-Core HD APU. Having a fanless metal material
(cassis either silver or gold-rose) and eMMC as storage (additional M2-SSD possible), it will have a long battery life.
Find out more on our hardware page.
If you are curious about the latest state of development for the upcoming Manjaro-Illyria 18.0 release,
you now have the opportunity to download a beta-build of Manjaro-Xfce 18.0 including the latest xfce-gtk3
packages aswell as our most recent styling efforts. Our KDE fans may try our beta-build with the latest KDE v5.13
instead. And our GNOME fans may try our beta-build with the latest GNOME v3.28.
Latest information about the intel-cpu-bug risk and our efforts can be found here.
Current supported Kernels
    linux316 3.16.57
    linux318 3.18.117 [EOL]
    linux41 4.1.52 [EOL]
    linux44 4.4.145
    linux49 4.9.117
    linux414 4.14.60
    linux415 4.15.18 [EOL]
    linux416 4.16.18 [EOL]
    linux417 4.17.12
    linux418 4.18-rc7
    linux414-rt 4.14.52_rt34
    linux416-rt 4.16.18_rt11
Package Updates (Sat Aug 4 20:19:38 CEST 2018)
    stable community x86_64: 741 new and 718 removed package(s)
    stable core x86_64: 22 new and 22 removed package(s)
    stable extra x86_64: 245 new and 244 removed package(s)
    stable multilib x86_64: 15 new and 15 removed package(s)
A list of all changes in details can be found here
Folgende Mitglieder bedankten sich: Nostradamus
Offline rolle
  • Neuling
  • Desktop: XFCE
  • Grafikkarte: Geforce GTX 650 Ti
  • Kernel: 4.14
  • Prozessor: Xeon E5-2690 V1
  • Skill: Anfänger
  • Zweig: stable
Re: [Update] 2018-08-06 - Kernels, Plasma, Jade, Deepin, Firefox, Haskell
« Antwort #1 am: 06. August 2018, 19:44:22 »
Hi, seit dem Update habe ich hier eine 2min Wartezeit.
Ansonsten läuft das System unauffällig.
[    3.912910] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[    3.912912] cdrom: Uniform CD-ROM driver Revision: 3.20
[    3.913034] sr 1:0:0:0: Attached scsi CD-ROM sr0
[  121.277832] EXT4-fs (sdc4): mounted filesystem with ordered data mode. Opts: (null)
[  129.093388] hpsa 0000:04:08.0: board not ready, timed out.
[  129.158681] systemd[1]: RTC configured in localtime, applying delta of 120 minutes to system time.
« Letzte Änderung: 07. August 2018, 06:40:45 von virtual-dev »
Offline rolle
  • Neuling
  • Desktop: XFCE
  • Kernel: 4.14
  • Skill: Anfänger
  • Zweig: stable
« Antwort #2 am: 07. August 2018, 15:18:21 »
Das kommt dabei raus:
[ralle@ralle-pc ~]$ timedatectl status
               Local time: Di 2018-08-07 15:08:08 CEST
           Universal time: Di 2018-08-07 13:08:08 UTC
                 RTC time: Di 2018-08-07 13:08:07
                Time zone: Europe/Berlin (CEST, +0200)
System clock synchronized: no
              NTP service: active
          RTC in local TZ: yes
Warning: The system is configured to read the RTC time in the local time zone.
         This mode cannot be fully supported. It will create various problems
         with time zone changes and daylight saving time adjustments. The RTC
         time is never updated, it relies on external facilities to maintain it.
         If at all possible, use RTC in UTC by calling
         'timedatectl set-local-rtc 0'.
[ralle@ralle-pc ~]$ systemctl status  systemd-timesyncd
● systemd-timesyncd.service - Network Time Synchronization
   Loaded: loaded (/usr/lib/systemd/system/systemd-timesyncd.service; disable>
   Active: inactive (dead)
     Docs: man:systemd-timesyncd.service(8)
Ich habe hier ein Dualboot mit Windows7 und es gab immer Probleme mit der Uhrzeit.
Die Zeiten waren in Windows und Linux unterschiedlich. Ich habe es nie hinbekommen.
Unter Windows läuft sie richtig. Das war mit wichtiger.
Die 2min Wartezeit trat aber nie auf.
Offline rolle
  • Neuling
  • Desktop: XFCE
  • Kernel: 4.14
  • Skill: Anfänger
  • Zweig: stable
« Antwort #3 am: 07. August 2018, 15:44:02 »
Es war der HP SAS Raid Controller, dieser steckte ungenutzt drin.
Jetzt ist er raus und es fluppt.
Wie kann man das Zeitproblem lösen? (Ist das zuviel für diesen Thread?)
Offline SpiritOfTux
  • Held Mitglied
  • Dankeschön: 183 mal
  • Desktop: KDE Plasma, Deepin
  • Grafikkartentreiber: On: NB intel/nvidia, HTPC nvidia, PowerWorkStation nvidia
  • Kernel: 4.14.y LTS, 4.9.y LTS,
  • Skill: Fortgeschritten
  • Zweig: stable 17.1.y on PowerWorkStation, NB, HTPC, Desktop:s: Testing or Unstable only VM
« Antwort #4 am: 07. August 2018, 15:50:57 »
@rolle                 RTC in local TZ: yes                  <<====
@virtual-dev        RTC in local TZ: no
@SpiritOfTux      RTC in local TZ: no
Offline SpiritOfTux
  • Held Mitglied
« Antwort #5 am: 07. August 2018, 16:13:40 »
System Time Setting https://wiki.manjaro.org/index.php?title=System_Time_Setting
Time https://wiki.archlinux.org/index.php/time
Offline rolle
  • Neuling
  • Desktop: XFCE
  • Kernel: 4.14
  • Skill: Anfänger
  • Zweig: stable
« Antwort #6 am: 09. August 2018, 14:37:15 »
Jetzt paßt es mit der Zeit.
Danke!
premete
  • Gast
« Antwort #7 am: 13. August 2018, 16:11:29 »
Leider hat es nicht geholfen: befehl 'sudo pacman -Syu' downloaded ~700 MB, after restart wieder ist mein Laptop nutzlos.
Kein FM, Dock nur im Teil sichtbar, kann man damit kein Anwendung starten, mit Super ikon starten Programme random nach ~10-20 sec.
https://photos.google.com/photo/AF1QipPc8fASCb5ulyMhBSh1ZZT6JxgBbc7UkaGBnFhs?hl=de
« Letzte Änderung: 13. August 2018, 16:13:52 von premete »
Offline gosia
  • Held Mitglied
  • Dankeschön: 292 mal
  • Desktop: Openbox + xfce
  • Grafikkarte: Intel HD 4000
  • Kernel: 4.19 Artix
  • Zweig: stable
« Antwort #8 am: 13. August 2018, 17:03:07 »
Hallo premete,
das Foto wäre besser auf einem öffentlichen ShareHoster aufgehoben, z.B. Imgur
https://imgur.com/
aber vielleicht sind ja einige schon bei Google angemeldet. Aber sich extra ein Konto einrichten müssen erschwert die Hilfe doch erheblich.
Viele Grüße gosia
premete
  • Gast
« Antwort #9 am: 13. August 2018, 17:26:06 »
https://imgur.com/kae4osq
Nach update sogar options aus pacman verschwunden, Laptop regiert nicht.
https://i.imgur.com/Fik9TnY.mp4
Offline SpiritOfTux
  • Held Mitglied
« Antwort #10 am: 13. August 2018, 17:47:38 »
Ein Copy & Paste sollte doch klappen sieh mal was @virtual-dev vorgegeben hat.
Zitat
sudo pacman -Syu
hier https://imgur.com/kae4osq wurde alles in klein Buchstaben geschrieben, nicht richtig, Übung macht den Meister  ;)
premete
  • Gast
« Antwort #11 am: 13. August 2018, 18:03:52 »
Nach copy/paste sudo pacman -Syu das System ist nutzlos: https://i.imgur.com/Fik9TnY.mp4
Genauso nach installierte manjaro deepin 18 beta4/5.
Offline SpiritOfTux
  • Held Mitglied
« Antwort #12 am: 13. August 2018, 19:41:43 »
Log dich mal im  Terminal ein, dann
mv .cache .cache.old                   # beachte den führenden Punkt
mv .config .config.old                   # beachte den führenden Punkt
mv .local .local.old                       # Dito
#reboot
# login auf der GUI
Zeige mal deine Hardware
inxi -Fxzc0 --usb
lspci -knn
