Autor Thema: [Update] 2018-10-19 - Kernels, KDE, Xorg, VB, PHP, Mesa, Nvidia, Pamac  (Gelesen 5813 mal)
Offline landtaipan
  • Vollwertiges Mitglied
  • Dankeschön: 49 mal
  • Desktop: xfce
  • Grafikkarte: nvidia
  • Grafikkartentreiber: free
  • Kernel: 5.x
  • Prozessor: Intel i7
  • Skill: Durchschnitt
  • Zweig: stable/testing
Zitat
philm - Manjaro Team
Hi community,
Welcome to another stable update. Since this update is huge we recommend to install
it from within a terminal: pamac upgrade or sudo pacman -Syu
So what do we have with this one?
We mostly focused on the K desktop environment. In Plasma there’s a new Display Configuration
widget for screen management which is useful for presentations. The Audio Volume widget now
has a built in speaker test feature moved from Phonon settings. The Network widget now works
for SSH VPN tunnels again. For the window manager copy-paste between GTK and non-GTK apps
on Wayland got fixed. Additonally many bugs got fixed: Blurred backgrounds behind desktop
context menus are no longer visually corrupted and it’s no longer possible to accidentally
drag-and-drop task manager buttons into app windows.
Then we worked on our boot experience and fixed grub-boot-success for grub-quiet. The menu should
now stay hidden as it should. Please report any edge cases you may still have with it.
Calamares gained the functionality to define how we may use swap.
Other changes in brief overview:
    We updated most of our kernels (linux419 uses now BFQ v9 as default scheduler)
    We added KDE Plasma 5.14.1, Apps 18.08.2 and Framework 5.51.0
    Xorg-Server is now at 1.20.2
    Mesa is now at 18.2.3
    Virtualbox has a new version
    Nvidia drivers are now at the new long-lived 410 series
    glibc and mkinitcpio got some fixes added. For the later you may take a look at this if you boot from USB
    Deepin and Gnome got some packages updated
    We fixed grub-boot-success for grub-quiet
    We worked on our themes
    We updated Firefox-Dev to v64 series
    PHP is now at 7.2.11 and JDK8 at 8.u192
    Updated Pamac to v7.2-beta1
    The usual upstream fixes incl. haskell
We hope with all these changes Manjaro to be more efficient for you all.
Current supported Kernels
    linux316 3.16.59
    linux318 3.18.124 [EOL]
    linux44 4.4.161
    linux49 4.9.134
    linux414 4.14.77
    linux417 4.17.19 [EOL]
    linux418 4.18.15
    linux419 4.19-rc8
    linux414-rt 4.14.71_rt44
    linux416-rt 4.16.18_rt11
Package Updates (Fri Oct 19 20:04:00 CEST 2018)
    stable community x86_64: 1228 new and 1203 removed package(s)
    stable core x86_64: 28 new and 27 removed package(s)
    stable extra x86_64: 651 new and 707 removed package(s)
    stable multilib x86_64: 22 new and 15 removed package(s)
A list of all package changes may be found here
Offline leesrott
  • Sr. Mitglied
  • Dankeschön: 9 mal
  • Desktop: i3
  • Grafikkarte: Intel 3rd Gen Core processor Graphics Controller
  • Kernel: Linux 4.4
  • Prozessor: intel core i5
  • Zweig: stable
Re: [Update] 2018-10-19 - Kernels, KDE, Xorg, VB, PHP, Mesa, Nvidia, Pamac
« Antwort #1 am: 21. Oktober 2018, 14:10:46 »
Seit dem Update habe ich Problem mit tmuxp.
~]$ tmuxp load .main.yml
  File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 578, in _build_master
    ws.require(__requires__)
  File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 895, in require
    needed = self.resolve(parse_requirements(requirements))
  File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 786, in resolve
    raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.ContextualVersionConflict: (colorama 0.4.0 (/usr/lib/python3.7/site-packages), Requirement.parse('colorama==0.3.9'), {'tmuxp'})
During handling of the above exception, another exception occurred:
  File "/usr/bin/tmuxp", line 6, in <module>
    from pkg_resources import load_entry_point
  File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3112, in <module>
    @_call_aside
  File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3096, in _call_aside
    f(*args, **kwargs)
  File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3125, in _initialize_master_working_set
    working_set = WorkingSet._build_master()
  File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 580, in _build_master
    return cls._build_from_requirements(__requires__)
  File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 593, in _build_from_requirements
    dists = ws.resolve(reqs, Environment())
  File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 781, in resolve
    raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'colorama==0.3.9' distribution was not found and is required by tmuxp
Gibt es eigentlich eine Möglichkeit, über pacman an die letzte Version zu kommen auch wenn man den Cache schon gelöscht hat? Bei einer Rolling Release vermutlich nicht so einfach? Danke!
Offline leesrott
  • Sr. Mitglied
  • Dankeschön: 9 mal
  • Desktop: i3
  • Kernel: Linux 4.4
  • Zweig: stable
« Antwort #2 am: 21. Oktober 2018, 21:48:09 »
Offenbar hat der Autor des Pakets den Fehler behoben (Version 1.5.0a-2):
https://git.archlinux.org/svntogit/community.git/commit/trunk?h=packages/tmuxp&id=a0cbc3ea0fa3f2ac354bbb25a072484592619b0d
Allerdings bekomme ich es nicht installiert. Bekomme folgenden Fehler.
~]$ sudo pacman -U community-a0cbc3ea0fa3f2ac354bbb25a072484592619b0d.tar.xz
Lade Pakete...
Fehler: Fehlende Paket-Metadaten in community-a0cbc3ea0fa3f2ac354bbb25a072484592619b0d.tar.xz
Fehler: 'community-a0cbc3ea0fa3f2ac354bbb25a072484592619b0d.tar.xz': Ungültiges oder beschädigtes Paket
