Autor Thema: Pale Moon: Release notes v28.3.0 (2019-01-15)  (Gelesen 182 mal)
Offline virtual-dev
  • Sr. Mitglied
  • Dankeschön: 693 mal
    • systemdfree
  • Desktop: Xfce4
  • Grafikkarte: Intel HD Graphics 630
  • Grafikkartentreiber: free
  • Kernel: 4.19 LTS
  • Prozessor: i7-7700HQ
  • Skill: Fortgeschritten
  • Zweig: *
« am: 15. Januar 2019, 19:53:21 »
This is a major development and bugfix release.
Changes/fixes:
    Added AV1 support for MP4/MSE videos. Please note that this is a reference library implementation and the upstream decoding lib currently has poor performance for higher resolutions (720p+). This is disabled by default; use the about:config preference media.av1.enabled to enable this codec.
    Changed the API used for video playback with FFmpeg 58+. This should solve performance issues with VPx.
    Redesigned the main toolbar icons as SVG images to make them HiDPI compliant.
    Fixed the sync notification (infobar) icon.
    Fixed a potential cycle collector resource leak.
    Added icons and controls to tabs to indicate if sound is playing the tab and if so, allowing the user to mute it with a click.
    This is a native implementation of the API in use in Basilisk and performs the same function as the "expose noisy tabs" extension, although the extension may still be preferred by some for e.g. skinning capabilities. The feature may be disabled with browser.tabs.showAudioPlayingIcon.
    Removed support for VR hardware.
    Fixed out-of-bounds sizes for CSS calculation strings.
    Removed the DirectShow component since it is no longer necessary.
    Removed Firefox Accounts integration, phase 1:
        Changed the Sync client to the one from Tycho.
        Made Sync optional at build time.
    Stopped trying to cater to addons.mozilla.org since they no longer offer anything useful to Pale Moon after the Great XUL Extension Purge™.
    Added an option to process favicons for optimal sized display and removing animations. Enable this with browser.chrome.favicons.process
    Fixed an incorrect preference reference in feed reader.
    Fixed an issue with lazy frame construction on display:contents elements. This should solve e.g. the use of mathjax in comments on stackoverflow.
    Media code improvements and cleanup (ongoing).
    Updated the DropBox useragent override to solve login issues.
    Fixed potential crashes due to shutdown observers in VTT and font lists. DiD
    Enabled some mistakingly-disabled optimizations in the JS JIT compiler.
    Fixed several potential crashes in JS. DiD
    Fixed several potential crashes in WebCrypto. DiD
    Fixed a potential crash in JS Range Analysis. DiD
    Fixed a potential crash in the layout engine due to combo boxes. DiD
    Fixed a potential shutdown crash in non-standard environments related to 2D Canvas. DiD
    Fixed a potential overflow in the PNG writer. DiD
    Fixed a potential double-free in the MAR signing utility. DiD
    Fixed an issue where URLs could be extracted cross-origin (CVE-2018-18494).
    Updated NSPR to v4.20.
    Updated NSS to 3.41, providing (among other things) full compatibility with the final version of TLS 1.3 on websites.
    Updated location.protocol to the latest spec.
    Updated Intersection Observers to the latest spec and enabled them by default.
    Updated the SQLite lib to 3.26.0.
    Fixed errors about the login manager's recipeManager not being available (yet).
    Switched status bar download arrow to SVG.
    Fixed a crash in IntersectionObservers.
    Fixed initialization of the Search service from browser code to avoid synchronous init.
    Added logging of performance warnings to devtools consoles.
    Fixed favicons in taskbar tab preview listings.
    Blocked Comodo IS dll < version 6.3 to prevent startup crashes.
    Fixed issues in the HTML form submit observer module.
    Limited resolving depth of CSS variables to a sane maximum (fixes cras.sh issue).
    Removed Mozilla's proprietary constructor on WebAudio's AudioContext, aligning it with the standard specification.
    Exposed the previously hidden preference in about:config for page thumbnail generation (some people prefer this for local privacy).
    Aligned Element.ScrollIntoView with the DOM specification. This improves, among other things, compatibility with the React framework.
DiD This means that the fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
Folgende Mitglieder bedankten sich: tetzlaff
Offline tetzlaff
  • Vollwertiges Mitglied
  • Dankeschön: 15 mal
  • Grafikkarte: Nvidia
  • Kernel: 4.20
  • Prozessor: AMD T1090
  • Skill: Durchschnitt
  • Zweig: stable
Re: Pale Moon: Release notes v28.3.0 (2019-01-15)
« Antwort #1 am: 16. Januar 2019, 18:50:45 »
Hallo.
Immer noch mein Lieblingsbrowser. Update natürlich ohne Probleme.
Viele Grüße, tetzlaff
Manjaro, Artix-Linux, Devuan
Offline landtaipan
  • Dankeschön: 48 mal
  • Desktop: xfce
  • Grafikkarte: nvidia
  • Kernel: 4.19
  • Prozessor: Intel i7
  • Zweig: stable/testing
« Antwort #2 am: 17. Januar 2019, 19:34:52 »
Hi,
finde auch, das Palemoon nach wie vor das macht was er soll,
unauffällig browsen :) Ohne Schnick und Schnack.
Gruß, landtaipan
Offline charly700
  • Sr. Mitglied
  • Dankeschön: 5 mal
  • Desktop: XFCE
  • Grafikkarte: PC: NVIDIA GeForce 930M
  • Kernel: immer den Neuesten und einen LTS-Kernel
  • Prozessor: Core i5-6200U
  • Zweig: stable
« Antwort #3 am: 20. Januar 2019, 20:03:29 »
Noch immer nicht im Stable. Leider. Dauert immer ein paar Tage.
Offline charly700
  • Sr. Mitglied
  • Dankeschön: 5 mal
  • Desktop: XFCE
  • Zweig: stable
« Antwort #4 am: 02. Februar 2019, 23:05:55 »
Habe jetzt auch die neue Version.
Problem: Ich habe einen 4K Monitor und im Palemoon werden mir die Internetseiten in lesbarer Größe angezeigt,
leider aber das Menü und die Seitenleiste (Lesezeichen) und auch das Fenster welches kommt wenn ich eine Datei speichern will,
sind klein und nicht lesbar.
Wen ich den Firefox nutze gibt es diese Probleme nicht.
Gibt es irgendwelche Einstellmöglichkeiten im Palemoon welche ich nicht finde?
Danke.
Charly
