Anbei das Verbindungsprotokoll:
[sudo] Passwort für manjaro:
Das hat nicht funktioniert, bitte nochmal probieren.
2020-12-23 16:30:06 DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
2020-12-23 16:30:06 OpenVPN 2.5.0 [git:makepkg/a73072d8f780e888+] x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Nov 6 2020
2020-12-23 16:30:06 library versions: OpenSSL 1.1.1h 22 Sep 2020, LZO 2.10
🔐 Enter Private Key Password: ********
2020-12-23 16:30:11 Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
2020-12-23 16:30:11 Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
2020-12-23 16:30:11 Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
2020-12-23 16:30:11 Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
2020-12-23 16:30:13 TCP/UDP: Preserving recently used remote address: [AF_INET]80.109.58.248:1194
2020-12-23 16:30:13 Socket Buffers: R=[212992->212992] S=[212992->212992]
2020-12-23 16:30:13 UDP link local: (not bound)
2020-12-23 16:30:13 UDP link remote: [AF_INET]80.109.58.248:1194
2020-12-23 16:30:13 TLS: Initial packet from [AF_INET]80.109.58.248:1194, sid=d889afcf e629a269
2020-12-23 16:30:13 VERIFY KU OK
2020-12-23 16:30:13 Validating certificate extended key usage
2020-12-23 16:30:13 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2020-12-23 16:30:13 VERIFY EKU OK
2020-12-23 16:30:13 VERIFY X509NAME OK: CN=raspberrypi_68fe57b8-b72d-4375-b6f9-e969529e2088
2020-12-23 16:30:13 VERIFY OK: depth=0, CN=raspberrypi_68fe57b8-b72d-4375-b6f9-e969529e2088
2020-12-23 16:30:13 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, 256 bit EC, curve: prime256v1
2020-12-23 16:30:13 [raspberrypi_68fe57b8-b72d-4375-b6f9-e969529e2088] Peer Connection Initiated with [AF_INET]80.109.58.248:1194
2020-12-23 16:30:14 SENT CONTROL [raspberrypi_68fe57b8-b72d-4375-b6f9-e969529e2088]: 'PUSH_REQUEST' (status=1)
2020-12-23 16:30:14 PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 10.8.0.1,block-outside-dns,redirect-gateway def1,route-gateway 10.8.0.1,topology subnet,ping 15,ping-restart 120,ifconfig 10.8.0.6 255.255.255.0,peer-id 2,cipher AES-256-GCM'
2020-12-23 16:30:14 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:2: block-outside-dns (2.5.0)
2020-12-23 16:30:14 OPTIONS IMPORT: timers and/or timeouts modified
2020-12-23 16:30:14 OPTIONS IMPORT: --ifconfig/up options modified
2020-12-23 16:30:14 OPTIONS IMPORT: route options modified
2020-12-23 16:30:14 OPTIONS IMPORT: route-related options modified
2020-12-23 16:30:14 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2020-12-23 16:30:14 OPTIONS IMPORT: peer-id set
2020-12-23 16:30:14 OPTIONS IMPORT: adjusting link_mtu to 1624
2020-12-23 16:30:14 OPTIONS IMPORT: data channel crypto options modified
2020-12-23 16:30:14 Data Channel: using negotiated cipher 'AES-256-GCM'
2020-12-23 16:30:14 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2020-12-23 16:30:14 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2020-12-23 16:30:14 net_route_v4_best_gw query: dst 0.0.0.0
2020-12-23 16:30:14 net_route_v4_best_gw result: via 192.168.99.1 dev wlp4s0
2020-12-23 16:30:14 ROUTE_GATEWAY 192.168.99.1/255.255.255.0 IFACE=wlp4s0 HWADDR=44:85:00:81:51:e6
2020-12-23 16:30:14 TUN/TAP device tun0 opened
2020-12-23 16:30:14 net_iface_mtu_set: mtu 1500 for tun0
2020-12-23 16:30:14 net_iface_up: set tun0 up
2020-12-23 16:30:14 net_addr_v4_add: 10.8.0.6/24 dev tun0
2020-12-23 16:30:14 net_route_v4_add: 80.109.58.248/32 via 192.168.99.1 dev [NULL] table 0 metric -1
2020-12-23 16:30:14 net_route_v4_add: 0.0.0.0/1 via 10.8.0.1 dev [NULL] table 0 metric -1
2020-12-23 16:30:14 net_route_v4_add: 128.0.0.0/1 via 10.8.0.1 dev [NULL] table 0 metric -1
2020-12-23 16:30:14 Initialization Sequence Completed
