Autor Thema: [Testing Update] 2020-01-24 - Kernels, Gamemode 1.5, Pamac 6.3  (Gelesen 56 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update ...
Some feature-updates:
Kernels got updated to their latest point-releases
Linux54 got some fixes backported for i915 driver
gamemode got updated to 1.5
Pamac 6.3 got finally released
The usual upstream fixes
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out our current 18.1.5 ISOs and give us the needed feedback. You might also want to give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.81
linux44 4.4.211
linux49 4.9.211
linux414 4.14.167
linux419 4.19.98
linux53 5.3.18 [EOL]
linux54 5.4.14
linux55 5.5-rc7
linux419-rt 4.19.94_rt38
linux54-rt 5.4.10_rt5
Package Changes (Fri Jan 24 19:45:17 CET 2020)
testing community x86_64: 318 new and 318 removed package(s)
testing core x86_64: 28 new and 27 removed package(s)
testing extra x86_64: 119 new and 119 removed package(s)
testing multilib x86_64: 7 new and 8 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
