Autor Thema: [Testing Update] 2020-01-28 - Kernels, Browsers, Vulkan  (Gelesen 67 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
« am: 29. Januar 2020, 05:41:01 »
Zitat
Hello community,
here is another Testing Update ...
Some feature-updates:
Most of the Kernels got updated
Updates to Palemoon and Firefox-dev
Newer Vulkan drivers
The usual upstream fixes
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 2, which we build on a regular basis against kde-git master packages. Also check out our current 18.1.5 ISOs and give us the needed feedback. You might also want to give our latest spin 6 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd 1. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.81
linux44 4.4.211
linux49 4.9.211
linux414 4.14.168
linux419 4.19.99
linux53 5.3.18 [EOL]
linux54 5.4.15
linux55 5.5.0
linux419-rt 4.19.94_rt39
linux54-rt 5.4.10_rt5
Package Changes (Tue Jan 28 21:12:47 CET 2020)
testing community x86_64: 351 new and 342 removed package(s)
testing core x86_64: 18 new and 20 removed package(s)
testing extra x86_64: 206 new and 257 removed package(s)
testing multilib x86_64: 6 new and 6 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
