Autor Thema: [Update] 2020-01-30 - Kernels, Browsers, Vulkan  (Gelesen 96 mal)
Offline tetzlaff
  • Vollwertiges Mitglied
  • Dankeschön: 17 mal
  • Grafikkarte: Nvidia
  • Grafikkartentreiber: free
  • Kernel: 5.4 LTS
  • Prozessor: AMD T1090
  • Skill: Durchschnitt
  • Zweig: stable
« am: 31. Januar 2020, 04:48:56 »
Zitat
philm - Manjaro Team
Hello community,
here is another Stable Update ...
Some feature-updates:
    Most of the Kernels got updated
    Updates to Palemoon and Firefox-dev
    Newer Vulkan drivers
    The usual upstream fixes
If you like following latest Plasma development you may also
like to check out our current version of manjaro-kde-dev,
which we build on a regular basis against kde-git master packages.
Also check out our current 18.1.5 ISOs and give us the needed feedback.
You might also want to give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch updated their default compression to zstd 5. We adopted to the
same standard. More and more packages will have the zst extension
from now on. If you get for what ever reason an error with ZSTD not
supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
    linux316 3.16.81
    linux44 4.4.211
    linux49 4.9.211
    linux414 4.14.168
    linux419 4.19.99
    linux53 5.3.18 [EOL]
    linux54 5.4.15
    linux55 5.5.0
    linux419-rt 4.19.94_rt39
    linux54-rt 5.4.10_rt5
Package Changes (Tue Jan 28 21:12:47 CET 2020)
    stable community x86_64: 354 new and 344 removed package(s)
    stable core x86_64: 18 new and 21 removed package(s)
    stable extra x86_64: 206 new and 257 removed package(s)
    stable multilib x86_64: 6 new and 6 removed package(s)
« Letzte Änderung: 31. Januar 2020, 04:53:46 von tetzlaff »
Manjaro, Artix-Linux, Devuan
