Autor Thema: [Testing Update] 2020-02-07 - Kernels, KDE Apps, Gnome Settings  (Gelesen 80 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update.
Some feature-updates:
Most of the Kernels got updated
KDE Apps got updated to 19.12.2 9
Small adjustments to the upcoming Gnome Edition
The usual upstream fixes
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 2, which we build on a regular basis against kde-git master packages. Also check out our current 19.0-pre4 ISOs and give us the needed feedback. You might also want to give our latest spin 4 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.81
linux44 4.4.213
linux49 4.9.213
linux414 4.14.170
linux419 4.19.102
linux53 5.3.18 [EOL]
linux54 5.4.18
linux55 5.5.2
linux419-rt 4.19.94_rt39
linux54-rt 5.4.10_rt5
Package Changes (Fri Feb 7 09:34:20 CET 2020)
testing community x86_64: 115 new and 112 removed package(s)
testing core x86_64: 20 new and 20 removed package(s)
testing extra x86_64: 325 new and 325 removed package(s)
testing multilib x86_64: 5 new and 5 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
