Autor Thema: [Testing Update] 2020-02-13 - Kernels, Mate 1.24, Plasma 5.18, Firefox-Dev, Hask  (Gelesen 40 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 167 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update.
Some feature-updates:
With Plasma 5.18 13 we have another LTS release. Test and report 9 back.
Systemd is now at 244.3. Please test and report any regressions.
Firefox-Dev starts 74 series
We updated Mate to 1.24 5
The usual Kernel updates
Haskell and Python updates with regular upstream package changes got added
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 6, which we build on a regular basis against kde-git master packages. Also check out our current 19.0-pre5 ISOs 14 and give us the needed feedback. You might also want to give our latest spin 6 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd 1. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.82
linux44 4.4.213
linux49 4.9.213
linux414 4.14.170
linux419 4.19.103
linux54 5.4.19
linux55 5.5.3
linux56 5.6-rc1
linux419-rt 4.19.94_rt39
linux54-rt 5.4.17_rt9
Package Changes (Thu Feb 13 07:34:12 CET 2020)
testing community x86_64: 1029 new and 978 removed package(s)
testing core x86_64: 38 new and 38 removed package(s)
testing extra x86_64: 160 new and 157 removed package(s)
testing multilib x86_64: 5 new and 5 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
