Autor Thema: [Testing Update] 2020-02-17 - Kernels, Firefox-Dev, Gnome, BinUtils, Wine 5.2, P  (Gelesen 52 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update.
Some feature-updates:
Some of our Kernels got updated
Firefox-Dev got updated to its fourth beta of 74 series
Gnome got some more updates
Fixes to binutils to support linux316 and linux44
Wine got updated to 5.2
Some more python updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out our current 19.0-rc2 ISOs and give us the needed feedback. You might also want to give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.82
linux44 4.4.214
linux49 4.9.214
linux414 4.14.171
linux419 4.19.104
linux54 5.4.20
linux55 5.5.4
linux56 5.6-rc2
linux419-rt 4.19.94_rt39
linux54-rt 5.4.19_rt11
Package Changes (Sat Feb 15 11:28:05 CET 2020)
testing community x86_64: 187 new and 182 removed package(s)
testing core x86_64: 10 new and 10 removed package(s)
testing extra x86_64: 104 new and 98 removed package(s)
testing multilib x86_64: 10 new and 5 removed package(s)
Quelle & weitere Infos
Ganz wichtig ist nach dem Update von openssh per sudo pacman -Syu, den daemon neu zu starten. Folgender Befehl ist dazu notwendig:
systemctl restart sshd
Linu74
« Letzte Änderung: 17. Februar 2020, 19:33:52 von Linu74 »
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
