Autor Thema: [Testing Update] 2020-02-19 - Plasma 5.18.1, NetworkManager 1.22.8, Browsers, PH  (Gelesen 45 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update.
Some feature-updates:
Plasma 5.18 got its first point-release 14, which fixes most of the reported issues
PHP is now at 7.4.3 1
Firefox 73.0 got its first point-release 5
Palemoon got renewed to 28.8.3 1
NetworkManager is now at 1.22.8 8
A lot of python and haskell updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 5, which we build on a regular basis against kde-git master packages. Also check out our current 19.0-rc2 ISOs 8 and give us the needed feedback. You might also want to give our latest spin 5 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.82
linux44 4.4.214
linux49 4.9.214
linux414 4.14.171
linux419 4.19.104
linux54 5.4.20
linux55 5.5.4
linux56 5.6-rc2
linux419-rt 4.19.103_rt42
linux54-rt 5.4.19_rt11
Package Changes (Wed Feb 19 08:52:21 CET 2020)
testing community x86_64: 918 new and 930 removed package(s)
testing core x86_64: 2 new and 2 removed package(s)
testing extra x86_64: 186 new and 186 removed package(s)
testing multilib x86_64: 7 new and 6 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
