Autor Thema: [Testing Update] 2020-02-21 - LibreOffice 6.3.5, Kernels, VirtualBox 6.1.4, Cala  (Gelesen 52 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update.
Some feature-updates:
LibreOffice got updated to 6.3.5 6
Some Kernels got updated
VirtualBox 6.1.4 4 added some needed fixes
Updates to our Calamares installer
A lot of python and haskell updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 4, which we build on a regular basis against kde-git master packages. Also check out our current 19.0-rc2 ISOs 5 and give us the needed feedback. You might also want to give our latest spin 2 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.82
linux44 4.4.214
linux49 4.9.214
linux414 4.14.171
linux419 4.19.105
linux54 5.4.21
linux55 5.5.5
linux56 5.6-rc2
linux419-rt 4.19.103_rt42
linux54-rt 5.4.19_rt11
Package Changes (Fri Feb 21 08:18:43 CET 2020)
testing community x86_64: 236 new and 225 removed package(s)
testing core x86_64: 10 new and 10 removed package(s)
testing extra x86_64: 207 new and 204 removed package(s)
testing multilib x86_64: 4 new and 4 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
