Autor Thema: xrdp - verbindung bricht ab nach login mit reminna  (Gelesen 54 mal)
Offline Steel-Cat
  • Neuling
  • Desktop: KDE
  • Grafikkarte: Radeon
  • Prozessor: AMD Ryzen
  • Skill: Anfänger
  • Zweig: Stable
« am: 21. Februar 2020, 19:27:47 »
Manjaro Gnome Linux 54 frisch aus der Tüte
xrdp mit yay installiert und als service verankert
dann auf client reminna gestartet.... eingeloggt und...
20200221-19:17:16] [INFO ] connected client computer name: rakash
[20200221-19:17:16] [INFO ] all channels are disabled by configuration
[20200221-19:17:16] [INFO ] Non-TLS connection established from 192.168.10.43 port 36412: encrypted with standard RDP security
[20200221-19:17:16] [DEBUG] MCS_CJRQ - channel join request received
[20200221-19:17:16] [DEBUG] xrdp_00007720_wm_login_mode_event_00000001
[20200221-19:17:16] [INFO ] Loading keymap file /etc/xrdp/km-00000407.ini
[20200221-19:17:16] [WARN ] local keymap file for 0x00000407 found and doesn't match built in keymap, using local keymap file
[20200221-19:17:21] [DEBUG] xrdp_wm_log_msg: connecting to sesman ip 127.0.0.1 port 3350
[20200221-19:17:21] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20200221-19:17:21] [DEBUG] xrdp_wm_log_msg: sending login info to session manager, please wait...
[20200221-19:17:21] [DEBUG] return value from xrdp_mm_connect 0
[20200221-19:17:21] [INFO ] xrdp_wm_log_msg: login successful for display 10
[20200221-19:17:21] [DEBUG] xrdp_wm_log_msg: VNC started connecting
[20200221-19:17:21] [DEBUG] xrdp_wm_log_msg: VNC connecting to 127.0.0.1 5910
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC tcp connected
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC security level is 2 (1 = none, 2 = standard)
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC password ok
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC sending share flag
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC receiving server init
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC receiving pixel format
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC receiving name length
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC sending pixel format
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC sending encodings
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC sending framebuffer update request
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: VNC error - problem connecting
[20200221-19:17:22] [DEBUG] Closed socket 17 (AF_INET 127.0.0.1:35396)
[20200221-19:17:22] [DEBUG] xrdp_wm_log_msg: some problem
[20200221-19:17:22] [DEBUG] xrdp_mm_module_cleanup
[20200221-19:17:22] [DEBUG] VNC mod_exit
[20200221-19:17:22] [DEBUG] Closed socket 16 (AF_INET 127.0.0.1:52502)
Wie kann man da tiefer debuggen?
Offline Steel-Cat
  • Neuling
  • Desktop: KDE
  • Skill: Anfänger
  • Zweig: Stable
Re: xrdp - verbindung bricht ab nach login mit reminna
« Antwort #1 am: 22. Februar 2020, 13:18:36 »
that was the solution
exit-with session weg!
https://forum.manjaro.org/t/not-able-to-rdp-from-windows-to-manjaro-vm-via-xrdp-xorg/94357/2
Damit habe ich:
Manjaro stable gnome auf einer Bhyve virtuell installiert
SSH und XRDP aktiv (kein VNC mehr von FreeNAS)
nächste Ziele:
- Sound in Firefox
- Bash statt zsh
- Postfix, uucp, imap
- cups
- libreoffice
- thunderbird(?)
- samba
