Autor Thema: [Testing Update] 2020-02-27 - LibGLVND, Latte-Dock, UKUI, Python, Haskell  (Gelesen 62 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update.
Some feature-updates:
libglvnd got updated to 1.3.1
latte-dock is now at 0.9.9 8
More work went into UKUI 55
A lot of python and haskell updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 2, which we build on a regular basis against kde-git master packages. Also check out our current 19.0 ISOs 4 and give us the needed feedback. You might also want to give our latest spin 2 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd 1. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.82
linux44 4.4.214
linux49 4.9.214
linux414 4.14.171
linux419 4.19.106
linux54 5.4.22
linux55 5.5.6
linux56 5.6-rc3
linux419-rt 4.19.103_rt42
linux54-rt 5.4.19_rt11
Package Changes (Thu Feb 27 08:47:02 CET 2020)
testing core x86_64: 2 new and 2 removed package(s)
testing multilib x86_64: 2 new and 2 removed package(s)
testing extra x86_64: 7 new and 6 removed package(s)
testing community x86_64: 540 new and 542 removed package(s)
A detailed list of all package changes can be reviewed here 6.
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
