Autor Thema: [Testing Update] 2020-03-07 - KDE-Git, Pamac 9.4, Haskell, Python  (Gelesen 92 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update for you:
Some feature-updates:
KDE-git packages got updated
More fixes to Pamac 9.4. Please check if your translations 4 are finalized.
A lot of python and haskell updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 2, which we build on a regular basis against kde-git master packages. Also check out our current 19.0.2 ISOs 1 and give us the needed feedback. You might also want to give our latest spin 1 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
linux316 3.16.82
linux44 4.4.215
linux49 4.9.215
linux414 4.14.172
linux419 4.19.108
linux54 5.4.24
linux55 5.5.8
linux56 5.6-rc4
linux419-rt 4.19.106_rt44
linux54-rt 5.4.22_rt13
Package Changes (Sat Mar 7 09:00:15 CET 2020)
testing community x86_64: 147 new and 147 removed package(s)
testing core x86_64: 1 new and 1 removed package(s)
testing extra x86_64: 16 new and 16 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
