Autor Thema: [Testing Update] 2020-03-16 - KDE Framework, Haskell, Python, Gnome Themes and E  (Gelesen 47 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update for you:
Some feature-updates:
Wifi-Fixes for linux414 and *linux419
Small fixes to Gnome extensions and themes
KDE Framework got updated to 5.68 5
Haskell and Python updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 3, which we build on a regular basis against kde-git master packages. Also check out our current 19.0.2 ISOs 3 and give us the needed feedback. You might also want to give our latest spin 1 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
linux316 3.16.82
linux44 4.4.216
linux49 4.9.216
linux414 4.14.173
linux419 4.19.109
linux54 5.4.25
linux55 5.5.9
linux56 5.6-rc6
linux419-rt 4.19.106_rt45
linux54-rt 5.4.24_rt15
Package Changes (Mon Mar 16 20:54:10 CET 2020)
testing community x86_64: 632 new and 652 removed package(s)
testing core x86_64: 9 new and 9 removed package(s)
testing extra x86_64: 176 new and 176 removed package(s)
testing multilib x86_64: 1 new and 1 removed package(s)
A detailed list of all package changes can be found here 7.
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
