Autor Thema: [Testing Update] 2020-03-19 - Kernels, KDE-Git, Appstream-data, Firefox-Dev  (Gelesen 57 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update for you:
Some feature-updates:
We updated some of our Kernels
archlinux-appstream-data got stripped of any <em> tags preventing package listing in pamac and gnome-software
KDE-Git package updates
PHP got updated to 7.4.4 and Firefox-Developer got pushed ot its fifth beta release
Haskell and Python updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 1, which we build on a regular basis against kde-git master packages. Also check out our current 19.0.2 ISOs 1 and give us the needed feedback. You might also want to give our latest spin 1 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
linux316 3.16.82
linux44 4.4.216
linux49 4.9.216
linux414 4.14.173
linux419 4.19.109
linux54 5.4.25
linux55 5.5.9
linux56 5.6-rc6
linux419-rt 4.19.106_rt45
linux54-rt 5.4.24_rt15
Package Changes (Mon Mar 16 20:54:10 CET 2020)
testing community x86_64: 632 new and 652 removed package(s)
testing core x86_64: 9 new and 9 removed package(s)
testing extra x86_64: 176 new and 176 removed package(s)
testing multilib x86_64: 1 new and 1 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
Offline Linu74
  • Administrator
  • Kernel: 5.4x
  • Zweig: testing
Ich berichtige mal meine Meldung mit einem Zitat aus dem Englischen Forum
Zitat
Update of HP Device Manager
The coming update of HP Device Manager requires manual intervention.
The filesystem permissions for the hplip folder may be different on your system.
The package default is 755. To ensure the correct permissions execute this command
sudo chmod 755 /usr/share/hplip/* -R
You are advised to use pacman to overwrite the offending files
sudo pacman -Syu --overwrite /usr/share/hplip/\*
Linu74
« Letzte Änderung: 19. März 2020, 19:34:09 von Linu74 »
