Autor Thema: [Testing Update] 2020-03-26 - Kernels, Browsers, UKUI, Pamac, Haskell & Python  (Gelesen 25 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 169 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel/Nvidia
  • Grafikkartentreiber: free/nonfree
  • Kernel: 5.4x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update for you:
Some feature-updates:
Some of our Kernels got updated
We renewed Firefox-Dev and Palemoon
More package updates for ukui
Pamac got some more fixes
Haskell and Python updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out our current 19.0.2 ISOs and give us the needed feedback. You might also want to give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
linux316 3.16.82
linux44 4.4.217
linux49 4.9.217
linux414 4.14.174
linux419 4.19.113
linux54 5.4.28
linux55 5.5.13
linux56 5.6-rc7
linux419-rt 4.19.106_rt45
linux54-rt 5.4.26_rt17
Package Changes (Thu Mar 26 06:02:06 CET 2020)
testing community x86_64: 380 new and 372 removed package(s)
testing core x86_64: 11 new and 11 removed package(s)
testing extra x86_64: 97 new and 97 removed package(s)
testing multilib x86_64: 1 new and 1 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
