Autor Thema: [Update] 2020-03-24-Kernels, KDE Frameworks 5.68, Gnome 3.36, LibreOffice 6.4.2  (Gelesen 56 mal)
Offline tetzlaff
  • Vollwertiges Mitglied
  • Dankeschön: 18 mal
  • Grafikkarte: Nvidia
  • Grafikkartentreiber: free
  • Kernel: 5.4 LTS
  • Prozessor: AMD T1090
  • Skill: Durchschnitt
  • Zweig: stable
Zitat
philm - Manjaro Team
Hello community,
here is another Stable Update for you.
    Note for Gnome users
    It is critical NOT to use a graphical environment when updating from 3.34 to 3.36 series of Gnome.
    Therefore switch to a TTY and use our CLI package managers.
        First switch to a TTY: CTRL+ALT+F3
        Login with your normal user in that terminal
        Perform your update: sudo pacman -Syyu or pamac upgrade --force-refresh
        Reboot your system after the update completed. Don't worry about not supported extensions.
        Gnome 3.36 will deactivate them for you.
Some feature-updates
    All Kernels got rebuild against GCC 9.3 toolchain
    Gnome got updated to 3.36. As usual report your issues!
    poppler packages got updated
    gamemode is updated to 1.5.1
    KDE-Git package updates
    Matcha theme got more fixes for Gnome 3.36
    Updated packages for manjaro-asian-input-support
    LibreOffice got updated to 6.4.2
    archlinux-appstream-data got stripped of any <em> tags preventing package listing
    in pamac and gnome-software
    PHP got updated to 7.4.4 and Firefox-Developer got pushed ot its fifth beta release
    KDE Framework got updated to 5.68
    Haskell and Python updates
If you like following latest Plasma development you may also like to check out our current
version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages.
Also check out our current 19.0.2 ISOs and give us the needed feedback. You might also want to
give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch updated their default compression to zstd. We adopted to the same standard.
More and more packages will have the zst extension from now on. If you get for
what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
    linux316 3.16.82
    linux44 4.4.217
    linux49 4.9.217
    linux414 4.14.174
    linux419 4.19.112
    linux54 5.4.27
    linux55 5.5.11
    linux56 5.6-rc7
    linux419-rt 4.19.106_rt45
    linux54-rt 5.4.26_rt17
Package Changes (Tue Mar 24 09:08:47 CET 2020)
    stable community x86_64: 1765 new and 1708 removed package(s)
    stable core x86_64: 58 new and 56 removed package(s)
    stable extra x86_64: 739 new and 928 removed package(s)
    stable multilib x86_64: 38 new and 39 removed package(s)
A detailed list of all package changes can be found here
Manjaro, Artix-Linux, Devuan
