Autor Thema: [Testing Update] 2020-05-01 - Kernels, Mesa 20.0.6, Gnome 3.36.2, Pamac 9.5beta,  (Gelesen 50 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 180 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel
  • Grafikkartentreiber: free
  • Kernel: 5.6x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
here is another Testing Update for you:
Some feature-updates:
Most of our Kernels and KDE-git packages got updated
json-c got updated to 0.14
Mesa got updated to 20.0.6
More fixes to Gnome 3.36 and Pamac 9.5b
AMDVLK is now at 2020.Q2.2
The usual upstream updates including Haskell and Python
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out stable release of Manjaro Lysia 20.0! XFCE, KDE and Gnome You might also want to give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
linux316 3.16.83
linux44 4.4.220
linux49 4.9.220
linux414 4.14.177
linux419 4.19.119
linux54 5.4.36
linux55 5.5.19 EOL
linux56 5.6.8
linux57 5.7-rc3
linux54-rt 5.4.28_rt19
linux56-rt 5.6.4_rt3
Package Changes (Thu Apr 30 19:09:43 CEST 2020)
testing community x86_64: 905 new and 906 removed package(s)
testing core x86_64: 13 new and 13 removed package(s)
testing extra x86_64: 114 new and 128 removed package(s)
testing multilib x86_64: 8 new and 8 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
