Autor Thema: [Testing Update] 2020-05-03 - Kernels, KDE-git, Pop-Shell  (Gelesen 74 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 180 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel
  • Grafikkartentreiber: free
  • Kernel: 5.6x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
Another testing branch update with some interesting updates for you!
Most of our Kernels got updated
KDE-git packages got updated
pop-shell extension got added for initial testing. Discuss it here 3
The usual upstream updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out stable release of Manjaro Lysia 20.0! XFCE, KDE and Gnome 1
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
linux316 3.16.83
linux44 4.4.221
linux49 4.9.221
linux414 4.14.178
linux419 4.19.120
linux54 5.4.38
linux55 5.5.19 EOL
linux56 5.6.10
linux57 5.7-rc3
linux54-rt 5.4.28_rt19
linux56-rt 5.6.4_rt3
Package Changes (Sun May 3 05:13:38 CEST 2020)
testing community x86_64: 131 new and 130 removed package(s)
testing core x86_64: 13 new and 13 removed package(s)
testing extra x86_64: 110 new and 110 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
