Autor Thema: [Testing Update] 2020-05-10 - KDE-Git, Thunderbird 68.8.0, Pamac 9.5  (Gelesen 43 mal)
Offline Linu74
  • Administrator
  • Dankeschön: 180 mal
  • Desktop: XFCE/i3gaps x86_64
  • Grafikkarte: Intel
  • Grafikkartentreiber: free
  • Kernel: 5.6x
  • Prozessor: Core2Duo + Intel® Core™ i5-2520M
  • Skill: Durchschnitt
  • Zweig: testing
Zitat
Hello community,
Another testing branch update with some interesting updates for you!
KDE-git packages got updated
Thunderbird is at 68.8.0
Pamac 9.5 got its released. Find out more
The usual upstream updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out our latst release candidates of Manjaro Lysia 20.0.1! XFCE, KDE and Gnome
Upstream notice
Arch
updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
linux316 3.16.83
linux44 4.4.222
linux49 4.9.222
linux414 4.14.179
linux419 4.19.121
linux54 5.4.39
linux55 5.5.19 EOL
linux56 5.6.11
linux57 5.7-rc4
linux54-rt 5.4.28_rt19
linux56-rt 5.6.10_rt5
Package Changes (Sun May 10 10:41:45 CEST 2020)
testing community x86_64: 96 new and 92 removed package(s)
testing extra x86_64: 32 new and 32 removed package(s)
Quelle & weitere Infos
Linu74
Manjaro XFCE/i3gaps x86_64bit auf ThinkPad X200, T520
Deutscher Manjaro IRC Channel auf Freenode #manjaro-deAusgaben im Code Block [^code]hier text einfügen[^/code] die ^ müßen entfernt werden
